Xmc 25rh256cxiq bios chip
  • lavie
    • Aug 2015
    • 90
    • southafrica
    Morning guys have anyone come across dis bios chip XMC 25RH256CXIQ it's not listed in the programmer and i hve the latest software and is not found cant be detected
  • Zickko10
    • Sep 2021
    • 85
    • Nigeria
    Re: Xmc 25rh256cxiq bios chip
    Try and replace the bios chip with another
    Make sure you use the one that have the same storage (mb) like the previous one
    • lavie
      • Aug 2015
      • 90
      • southafrica
      morning sir thanks for ur feedback how can i check de chip when i dont hve the bios bin to programmed it with
        • 21994
        And your programmer model is what ?
        • lavie
          • Aug 2015
          • 90
          • southafrica
          is TL866II programmer and i have downloaded the latest software but is still not found in it
            • 21994
            Choose a different chip instead and untick the Check-ID box .You might have to untick verify as well
            W25Q256FV @SOIC8
            If you want full support adding send them an email - http://www.autoelectric.cn/en/ContactUs.html
            EDIT: Support was added on Date : 3.05th.2022 http://www.autoelectric.cn/MiniPro/TL866II_List.txt
            • i4mm3
              Banned
              • Sep 2020
              • 21
              • Philippines
              Did anyone get a successful unlock with this chip or replaced it with another chip? My laptop was awarded by company and I got everything even it's own box
              • Kodza
                • Jun 2016
                • 194
                • South Africa
                Hello guys I also got a laptop with the XMC 25RH256CXIQ and the chip is not supported my programmer is RT809H. I have tried to add the chip manually but it can't read the firmware from the chip
                • Aditya11ttt
                  Adi
                  • Feb 2019
                  • 190
                  • India
                  if try to replace with another chip display will come but along with diffrent kind of issue we have seen this in dell 5420 model only xmc chip works fine try any other brand not work proper.
                  • takura
                    • Sep 2016
                    • Zimbabwe
                    I have read the xmc 25rh256cxiq on my RT809H with no problems and wrote on it as well
                    • abdelilahocs
                      • Nov 2018
                      • 119
                      • morroco
                      i cant read it on RT809H and TL866II
                      • DZ-Developer
                        • Nov 2022
                        • 28
                        • Algeria
                        Same problem with XGecu T56
                        all donations are welcome,
                        see the donate button below, at the bottom of the page, or
                        >>>>> click on this link to donate via PayPal. <<<<<
                        Doctrina est fructus dulcis, radicis amarae
                        • krystian666
                          • Jun 2020
                          • 11
                          • Ecuador
                          Rt809f reads and writes without problem
                          enter correct id and it works ok
                          • codex16
                            • Jan 2023
                            • morocco
                            hi i have RT809F with last update 20221212 i cant read XMC25RH256CXIQ not in list i use MX25L25635E but dump is not working can you help mais plz
                            • codex16
                              • Jan 2023
                              • morocco
                              can you plz share Rt809f upload full software ?
                                • 21994
                                https://www.badcaps.net/forum/showpo...40&postcount=2
                                1.1.1.3. RT809F
                                Supports I2C, SPI, LPC, FWH, VGA ISP.
                                Parallel interfaces support requires PEB-1 extension board and can be troublesome.
                                Support list: https://www.hklrf.com/24download/img/RT809F-List2.txt
                                Software: http://doc.ifix.net.cn/@rt809/ENGLISH.html
                                See post #13 to change the chip ID .
                                • feherhollo
                                  • Nov 2019
                                  • 110
                                  • Hungary
                                  I'm also unable to read out this chip using RT809F
                                  Can somebody tell how can you read out this chip?
                                  These are getting very common in Dell 11th gen laptops...
                                    • 21994
                                    Did you read post #13 ,maybe that will work.
                                    • Ismael Shah
                                      • Jul 2021
                                      • 8
                                      • india
                                      Thanks for help
                                      • bachir2004
                                        • Feb 2015
                                        • 439
                                        • maroc
                                        Confirmed.software needs to be restarted.
