Hp 470 G1 ME state in recovery mode
  • max2711
    • Jan 2012
    • 62
    • Croatia
    Please fix my bios
    MB is Rampage_MB 12241-1 48.4yw03.011
  • DanielDacko
    • Mar 2015
    • 326
    • Macedonia
    Re: Hp 470 G1 ME state in recovery mode
    Try...
    I don't provide help for people using CH341A and a clip.
    • max2711
      • Jan 2012
      • 62
      • Croatia
      Thank You, Daniel
      Now I have mesage:Machine is not in commited state
      I try nbdmifit and other tools but no succes.
      • DanielDacko
        • Mar 2015
        • 326
        • Macedonia
        Originally posted by max2711
        Thank You, Daniel
        Try now.
        • volinakis
          Chromebook recovery failed - how to fix it
          by volinakis
          So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
          Finally I found a site where they suggested to try with an older image and ... it worked!
          What I did:
          - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
          09-18-2023, 03:26 PM
        • Maxpower3
          HP 650 G1 ME state in recovery mode
          by Maxpower3
          Hello
          Need help ME state in recovery mode on HP 650 G1
          even after bios update with ethernet. still the same...
          09-16-2022, 06:09 AM
        • myth77
          macbook pro a2141 can not make recovery
          by myth77
          So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
          So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
          06-19-2022, 11:21 AM
        • ugamazing
          820-00850 & 820-01949, No WiFi *In Recovery*
          by ugamazing
          I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
          1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
          2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
          01-25-2023, 05:39 PM
        • pfrcom
          HP ProBook 5330m "ME is in Recovery State..."
          by pfrcom
          I recovered bricked 5330m by means of https://www.badcaps.net/forum/showpo...04&postcount=4
          Then filled in missing system parameters using NBDMIFIT (v2.13 iirc)
          But can't work out how to stop "ME is in Recovery State..." on every boot
          Hoping some of the dross from Googling was worthwhile, I subsequently updated BIOS to latest version F.66 rev.A under DOS, and updated ME under Win10 CLI (wouldn't work under DOS) using commands extracted from SP80144.exe
          FWIW, ME update's "FWUpdLcl.exe -f /ME/ME7_5M_UPD_Production.bin...
          07-28-2021, 12:48 AM
