HP 14-dq 14s-dq DA0PADMB8F0 REV:F
  • lazybigyan
    • Mar 2017
    • 79
    • Nepal
    I have HP 14-dq1040wm DA0PADMB8F0 REV:F with black screen. I need some help with this bios. I need bios.
    And old bios is attached
  • peste
    • Dec 2016
    • 12868
    • ROMANIA
    Re: HP 14-dq1040wm DA0PADMB8F0 REV:F
    you do not have the original bios ?? this bios has been configured before ..
    • lazybigyan
      • Mar 2017
      • 79
      • Nepal
      This is the bios (orginal) with black screen. I didn't have any other working bios.
      It is just backup bin file
      • lazybigyan
        • Mar 2017
        • 79
        • Nepal
        Still I am waiting.
          • 21011
          Still I am waiting.
          Post the serial number on the case
          • _F.fernan
            • 73
            • Philippines
            sir SMDFLea i have the same unit . The problem is it power indicator lits up few seconds only then shuts off . here is my serial S/N :5cd9433hyx
            • _F.fernan
              • 73
              • Philippines
              Sir i need your help
              • hoaca388
                Badcaps
                • Jan 2022
                • 11807
                still i am waiting.
                • _F.fernan
                  • 73
                  • Philippines
                  Originally posted by hoaca388
                  Hi brother . will it work on my unit ? my model number is 14s-DQ1037TU
                  • vappisc
                    • May 2021
                    • santa fe
                    I downloaded this dump from an HP 14-dq1040wm that doesn't work at power-on due to a short in one of the power lines, I'm not sure if it's working
                    • Saifudheen easycare
                      • Feb 2021
                      • 9
                      • united arab emirates
                      [[/php][/php]
                      i have hp 14-dq1040wm da0padmb8f0 rev:f with black screen. I need some help with this bios. I need bios.
                      • lrservicios
                        • May 2016
                        • 130
                        • españa
                        HP 14s-dq series turn on and off loop
                        Hi i have a HP 14s-dq2013ns S/N: 5CD127GRLV DA0PADMB8F0 REV : F
                        Laptop start and shuts off after 1-2 seconds i think maybe BIOS is corrupted, can anone check my dump and clean it please ? here i post original dump
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          Re: HP 14s-dq series turn on and off loop
                          https://www.badcaps.net/forum/showthread.php?t=103526
                          6. Finding bios update packages
                          6.1.8 HP
                          See:
                          [Guide] How to extract ready for programming dump from HP update executable file
                          https://www.badcaps.net/forum/showthread.php?t=121948
                          https://www.badcaps.net/forum/showth...51#post1261151
                          When you`ve found and extracted the right bios using the guides above you can add the DMI (serial number,featurebyte etc) and Windows key to the new bios using following offsets
                          DMI: 801000 - 8020FF
                          Win key: 886000 - 88603F
                          Become a Badcaps supporter
                          Thanks to all supporters.
                          • Sebas3124
                            • Mar 2014
                            • 15
                            • Colombia
                            Re: HP 14-dq 14s-dq DA0PADMB8F0 REV:F
                            try this, is ok
                            • rex98
                              • Feb 2023
                              • 1280
                              • Mandaue CEBU, Philippines
                              this main bios works without DMI data. just flash directly.
                              give feedback.
                              • cainhos
                                • Oct 2017
                                • 4
                                • portugal
                                HP 14-dq 14s-dq DA0PADMB8F0 REV:F I need someone to help me to remove password please!
                              • gigasi
                                • Dec 2016
                                • 97
                                • Argentina
                                Hello, I have a hp 14-dq 1040wm. It turns on and the numlock flashes 5 times. then 3 quick ones. The equipment has already been reprogrammed, the bios, I don't know if it is the original. Leave a copy and label of the model. The plate made is da0padmb8f0 rev f Model: 0PAD.
                                thank you.​
                                  • 21011
                                  thank you.
                                  You MUST:
                                  • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                  • cainhos
                                    • Oct 2017
                                    • 4
                                    • portugal
                                    this is my serial and model .. and original bios
                                    • Vesko356
                                      Vesko356 commented
                                      Editing a comment
                                      Read the rules before posting
                                      You MUST:
                                  • cainhos
                                    • Oct 2017
                                    • 4
                                    • portugal
                                    HP 14-dq 14s-dq DA0PADMB8F0 REV:F Model 14-dq1039wm Serial: 5CD941HGX4 BIOS DUMP Original Width Password , Please Help me to remove THanks
                                  • macabook
                                    by macabook
                                    🧩 Initial Issue
                                    07-24-2025, 02:17 PM
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
