And old bios is attached
HP 14-dq 14s-dq DA0PADMB8F0 REV:F
I have HP 14-dq1040wm DA0PADMB8F0 REV:F with black screen. I need some help with this bios. I need bios.
And old bios is attachedTags: None -
Every donation made will go towards server fees and maintenance costs. -
Re: HP 14-dq1040wm DA0PADMB8F0 REV:F
Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
I downloaded this dump from an HP 14-dq1040wm that doesn't work at power-on due to a short in one of the power lines, I'm not sure if it's workingAttached Filesif you find these attachements useful please consider making a small donation to the site
[[/php][/php]Attached Filesif you find these attachements useful please consider making a small donation to the site
HP 14s-dq series turn on and off loop
Hi i have a HP 14s-dq2013ns S/N: 5CD127GRLV DA0PADMB8F0 REV : F
Laptop start and shuts off after 1-2 seconds i think maybe BIOS is corrupted, can anone check my dump and clean it please ? here i post original dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: HP 14s-dq series turn on and off loop
https://www.badcaps.net/forum/showthread.php?t=103526
6. Finding bios update packages
6.1.8 HP
See:
[Guide] How to extract ready for programming dump from HP update executable file
https://www.badcaps.net/forum/showthread.php?t=121948
https://www.badcaps.net/forum/showth...51#post1261151
DMI: 801000 - 8020FF
Win key: 886000 - 88603F
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Re: HP 14-dq 14s-dq DA0PADMB8F0 REV:F
try this, is ok
this main bios works without DMI data. just flash directly.
give feedback.Attached Filesif you find these attachements useful please consider making a small donation to the site
HP 14-dq 14s-dq DA0PADMB8F0 REV:F I need someone to help me to remove password please!
ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Hello, I have a hp 14-dq 1040wm. It turns on and the numlock flashes 5 times. then 3 quick ones. The equipment has already been reprogrammed, the bios, I don't know if it is the original. Leave a copy and label of the model. The plate made is da0padmb8f0 rev f Model: 0PAD.
thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
2 PhotosComment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTINGHello, I have a hp 14-dq 1040wm. It turns on and the numlock flashes 5 times. then 3 quick ones. The equipment has already been reprogrammed, the bios, I don't know if it is the original. Leave a copy and label of the model. The plate made is da0padmb8f0 rev f Model: 0PAD.
thank you.
this is my serial and model .. and original biosAttached Filesif you find these attachements useful please consider making a small donation to the site
Read the rules before posting
HP 14-dq 14s-dq DA0PADMB8F0 REV:F Model 14-dq1039wm Serial: 5CD941HGX4 BIOS DUMP Original Width Password , Please Help me to remove THanksAttached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
7.1. Desktops
7.2. Laptops
7.2.1. Acer
7.2.2. Asus
7.2.3. Dell
7.2.4. HP
7.2.5. Lenovo
Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
Hints:
1. 086C8
2. DMI 480000-4810FF
3. WinKey A9E000-A9E03F
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
