Lenovo Ideapad S-145-15IIL BIOS
Re: Lenovo Ideapad S-145-15IIL BIOS
The same issue like "linxz".after windows logo is frozen , no video just backlight.if i disconect de battery and power adapter 30 sec it power on normal and boot ok.after shut down and power on i can see lenovo logo and after that windows logo .it frozen , no vidro just backlight.
I dont know what is wrong, after bios update is die.
May be different issue?
Thank you "lapfix".Comment
Thank you "lapfix".
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
try and give good newsAttached FilesComment
The files we send you are all virgin bios, so if it doesn't work, there's a good chance you've got more other error.
After many hours i think i solve the problem.
Ssd was empty and i put windows 10 legacy and after shut down and start again , laptop is frozen.
I put windows 10 uefi and after shut down and start again it boot fine.
I think this was the problem.
I will test it again tomortow and i will let you know.
Thank you very much to all of you for your help and patince.Comment
If you want to learn more about programmers, read that post.
https://www.badcaps.net/forum/showpo...40&postcount=2
It's also better to write your device serial number, you can find it in the bottom cover.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Re: lenovo IdeaPad S145 bios needed
I have a issue when i program this file my laptop give display after 35 sec please help me mn-c711 bios dump then my laptop on normallyComment
Every donation made will go towards server fees and maintenance costs.Comment
With my bios i have no image, no blinks, please help I need bios without on board ram, I had to remove them for a ShortAttached FilesLast edited by Fadda88; 05-16-2023, 08:59 AM.Comment
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
Channel: BIOS Requests ONLY!
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by Popel1083Hi,
I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
SN: QB08570065
MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02-
- Loading...
