Lenovo ideapad 5-14IIL05 BIOS bin
LENOVO IDEAPAD FLEX_5 14ITL05 (203044-1) 100% WORKINGComment
IdeaPad 5-14ITL05 Laptop - Type 82FE
SN:MP22FAKW
POWER LED AND ESC LED LIGHTS FOR A CUOPEL SEC AND THEN NOTHING
PLEASE I NEED THE TWO FILES BIOS AND IT WILL BE GREAT IF YOU CAN ADD THE SN AND WIN KEY
THANKS IN ADVANCEDAttached FilesLast edited by MK-1; 08-14-2024, 05:45 AM.Comment
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hello.
I need help with bios IdeaPad 5-14ITL05 Laptop - Type 82FE
SN:MP23R2EZ
Black screen.Comment
Every donation made will go towards server fees and maintenance costs.Comment
Model- Ideapad 5 14IIL05
Model Name-81YH
S/N-MP1VMDK4
Motherboard Part no.-FLMS0 LA-J551P Rev:2B 2020-08-21
no display problem plz provide the working bios file
Attached FilesComment
SN:MP21QJK9
Looking for clean Bios file
Attached are original 16 & 8MB filesAttached FilesComment
I'm having the exact same problem with my board, can someone please help me?Attached FilesComment
you have everything you need for the post#2..
https://www.badcaps.net/forum/troubl...hlight=14ITL05
I opened them with HxD and I noticed that the serial number and windows key are in the biggest one (16MB), so i could actually replace them myself but i don't know if some sort of modification needs to be done also in the other file (8MB).
Can someone pls explain me the right way to do it?
thanksComment
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
- Loading...
