Lenovo ideapad 5-14IIL05 BIOS bin
  • lightfinger
    • Jun 2020
    • 12
    • United Kingdom
    anyone got a bios bin for the ideapad 5-14IIL05? The one I got is making the laptop blink the powerlight and CPU go warm. BIOS seems to not do POST.
    • 20989
    Re: Lenovo ideapad 5-14IIL05 BIOS bin
    Post your backup
    • lightfinger
      • Jun 2020
      • 12
      • United Kingdom
      my backup is corrupt as the bios chip itself was bad.
        • 20989
        Post the corrupt backup ,there might be some DMI info. What programmer and software version are you using.
        • lightfinger
          • Jun 2020
          • 12
          • United Kingdom
          I'm using the below.
          tried on both CH314A and RT809F
          tried the AIR-14IIL 2020 FLMS0 LA-J551P Rev 1.0 - all power lights blink continuously including function lock with CPU GPU and SSD heating up.
          Got a 8MB extract and a 16 MB extract both using CH314A and is attached
          Modified the bios section for the FLMS0 LA-J551P Rev 1.0 BIOS with same result.
          To modify used HEX Workshop v6.7
          Programmer version 1.38 for CH314A
          Programmer version 20210410 for RT809F
          • lightfinger
            • Jun 2020
            • 12
            • United Kingdom
            with attachments
              • 20989
              with attachments
              Bios + EC .Your version is DSCN34WW (DOSFLMS0) . ideapad 5-14IIL05 Laptop - Type 81YH
              The other one is for some of the other models listed (Use hex editor text search: BVDT)
              IdeaPad 5 14IIL05,14IIL05 U,14IIL05 D, XiaoXin-14IIL 2020, XiaoXinAir-14IIL 2020, Lenovo Ducati 5
              • lightfinger
                • Jun 2020
                • 12
                • United Kingdom
                Thank you very much. You saved my day.
                • O.Szilard
                  • May 2019
                  • 161
                  • hungary
                  Re: Flex 5-15IIL05 / LC55-15C
                  Hello, please help Lenovo Flex 5 14IIL05 81X1
                  LC55-15C 19792-1 448.OK106.0011 SEARCH BIOS dump. The machine turns on, cpu cooler rotates high, the screen is black
                    • 20989
                    Try this one and leave feedback .
                    Flex 5-14IIL05 Laptop (ideapad) - Type 81X1
                    ECCN36WW
                    • O.Szilard
                      • May 2019
                      • 161
                      • hungary
                      Thanks, but same problem. CPU fan with high speed and black screen
                      • bushmann
                        • Feb 2014
                        • 147
                        • Slovakia
                        Please can you help me.
                        I read this model from BIOS, but I don`t know is it correct " Flex 5-14iil05 ".
                        After BIOS update not start.
                        I need EC file for motherboard model
                        LC55-15C
                        19792-SB
                        448.0K106.00SB
                        this model have Nuvoton EC ic and not have Nvidia GPU.
                        thanks for your help.
                        • peste
                          • Dec 2016
                          • 12859
                          • ROMANIA
                          LC55-15C
                          19792-SB
                          448.0K106.00SB
                          posts the original bios of the laptop, the full name and model and TYPE ....
                          • bushmann
                            • Feb 2014
                            • 147
                            • Slovakia
                            So I have a Flex 5-14iil05 model and this model has a Nuvoton EC.
                            I don't know if it's the right model, I read it from the BIOS.
                            The customer updated the BIOS and did not start after the restart.
                            Flash for EC is empty "FF".
                            This model does not have a Nvidia GPU.
                            LC55-15C
                            19792-SB
                            448.OK106.00SB
                            I didn't find any label on the laptop itself, just what I wrote.
                            Thanks.
                              • 20989
                              LC55-15C
                              19792-SB
                              448.OK106.00SB
                              @peste asked you for the machine type, if you don`t know what it is post the serial number,or a picture of the sticker on the base
                              • bushmann
                                • Feb 2014
                                • 147
                                • Slovakia
                                Nothing is written on the base.
                                I don't know the model or the serial number.
                                I already had several models that had nothing on the base.
                                I looked but I didn't find anything. If I had some of these numbers, I wouldn't write here. I only have the label on the motherboard, which I wrote above. I read the model I wrote above from the BIOS chip.
                                I have no further information.
                                • dhibubabu
                                  • 50
                                  • UAE
                                  Bios need ideapad flex 5 14iil05 81x1
                                  LC55-15c
                                  19792-3
                                  448.0k105.0031
                                  orginal bios is no display,ATTACHED
                                  • peste
                                    • Dec 2016
                                    • 12859
                                    • ROMANIA
                                    Re: Bios need ideapad flex 5 14iil05 81x1
                                    LC55-15c
                                    19792-3
                                    448.0k105.0031
                                    try post # 10 ....
                                    https://www.badcaps.net/forum/showth...d+flex+14iil05
                                    • dhibubabu
                                      • 50
                                      • UAE
                                      once i program that file
                                      display on and backlight only (blank display)
                                      then i turned off and on again
                                      no display
                                      • peste
                                        • Dec 2016
                                        • 12859
                                        • ROMANIA
                                        no display
                                        is the bios extracted from the Lenovo site update, either you typed it in error, or the laptop has another problem ...
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          Yesterday, 03:01 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
