eda50 la-h271p bios help please
  • mgjini
    • Sep 2017
    • 199
    • united kingdom
    hello all
    originaly this laptop eda50 la-h271p / Precision 7540 it had bios password, i tried to unlock it, so i install file back on and some bios give me fan spin, but not working so i decided to install back original file which i am including here but this is not working any longer, laptop doesn't start anymore, i was wondering if anybody can help,original file included here
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: eda50 la-h271p bios help please
    So the game over in tears and regrets huh?
    (SMDFlea was absolutely right, guide for dumping a bios file should be written.)
    So try it, I hope it will be fine, if not there is another solution too.
    And use verification after programming the chip, also read chip again and compare the content.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • mgjini
      • Sep 2017
      • 199
      • united kingdom
      hi Vesko356 yes in this case i regret taking it on as this seems new generation laptop and not worth it for me, now broken laptop and no solution, i tried this bios and same issue, 1 light, 2 lights and nothing no fan spin or nothing cpu not getting hot
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Strange, it should work with this file. Did you verify the content of the chip? Did you solder/desolder the chip correctly (also check voltage at pin #8)? Take high resolution photos (and upload them here) of the bios chip area. You may have unnoticed damaged some small component from the surrounding area.
        • mgjini
          • Sep 2017
          • 199
          • united kingdom
          Hello Vesko356 I have taken some pictures and some measurements also on the pictures, I get 3.36v on some points but on some there is 0.42v and opposite 0v please kindly see pictures, when I tried to unlock this bios I use lbe paid membership, I ticked reset nvram and reset pram during the compilation of new bios, as far as I know I have not knocked any components as I use microscope
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            OK, lets try the recovery method, format some usb flash drive in fat32 filesystem, unzip the attached archive, and copy the recovery file to the root of the flash drive. Insert the flash drive into a USB port, remove the battery, press and hold the CTRL and ESC keys on the keyboard (laptop keyboard don't use usb keyboard), and insert the power jack into the laptop, keep pressed the CTRL and ESC keys until the BIOS recovery page appears.
            • mgjini
              • Sep 2017
              • 199
              • united kingdom
              Hi Vesko356, please give me few days to try, just now I tried a hp 650 g4 which also uses big chip, I use this guys program to remove hp password, I have bought about 2-3 days ago a Chinese sop 8x6mm and 2 tries i brake to laptops, so now this hp 650 g4 all I had to do is remove password which lbe does and install file back, I install file back, I am having fast fan spin, I am trying all rams model still same issue, but normally when I install original file back laptop should go back to its original state, in this case even original file is not working now fan fast spin, I can't figure out what is braking those 256 chips, the connector is reading the chips fine, why aren't laptops going back to original state with original file, I don't know if I am choosing the right option file on rt809h programmer should I be clicking on some other down the column, please see pictures,
                • 22001
                The laptop is under warranty, ProSupport Plus ⦁ Expires 13 JAN 2024
                With one phone call and with proof of ownership it would have been unlocked........
                • mgjini
                  • Sep 2017
                  • 199
                  • united kingdom
                  i buy pallets of laptop so is nothing to do with me that
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Reading the chip is a simple job with the appropriate tools, with the patience and using a common sense - read the data from the chip twice and save it to a file each time.
                    Verify the checksum of both files.
                    This is to make sure that there is no corruption when reading data from the chip. Did you do that? Of course no!
                    And this leads to a situation in which none of us is sure that the backup is good. And probably it isn't. Because if it was good, the laptop would have to power on again.
                    Almost the same story as this one.
                    Five minutes of extra work to secure yourself from troubles. Simple as that.
                    • mgjini
                      • Sep 2017
                      • 199
                      • united kingdom
                      So I have a hp 830 g5, which also has this big chip and I am not comfortable to sell this laptop, so I decided to create bios password and test again the procedures, with other chips I always try to find the name on the list which is printed on the chip for example I would find mxl12875f rather then on right side click on the first one on the list, so with this 830 g5 I decided to scroll down to find the closest name like printed to the chip rather then choosing the first one, so this laptop works this way, but choosing what I have highlighted on the picture broke 2 laptops, I am going to choose on the hp 650 g4 which had bios password I will choose a different file rather then the one on the picture
                      So far choosing what is ok the rt809h first file on the list broke, hp 650 g4, dell precision 7480, dell xps 13 9360, those all have big chips, hp 830 g5 working after choosing the file which is closest printed on the chip
                      • mgjini
                        • Sep 2017
                        • 199
                        • united kingdom
                        I don't want to flood this post but just an update, so by choosing the first file on rt809h broke 3 laptops of mine, one of them was a 650 g4, I have 2 of those, so I decided to remove chip from the other one and put on this one and now laptop works, I have tried to put the original file where I took it from and i had same issue, so somehow I have to replace the chips on those other laptops
                        • Anchar777
                          Anchar
                          • Apr 2018
                          • 4
                          • Austria
                          My friend, there was a problem with finding DUMP for this laptop. Is this dump a worker, but unfortunately the password in the BIOS remained . Can you help me take it off? and if it 's not difficult to clean ME region right away with BG fixed to 0 ? Thanks.
                          • cristiannec
                            • Oct 2014
                            • 51
                            • Italia
                            Hello, can someone please help me with fixing this bios?
                            Update got stuck at 80%, and now no power.
                            Only amber light when power button is pressed.
                            Recovery CTRL + ESC not responding
                            Many Thanks!
                            LA-h271P REV1.0
                            Dell Precision 7540
                            LE: CANNOT PROVIDE SERVICE TAG/ SNID. System worked , but from time to time when powered on, it entered manufacturer mode , and service tag was was blank. On the rear of the laptop sitckers were damaged so i was unable to read it. I'll ask client if he can provide me with service tag or serial numbr.
                          • claudiuccg
                            • Apr 2021
                            • 11
                            • Romania
                            for me is working but it has password
                          • qayyum786
                            • Aug 2018
                            • 1959
                            • INDIA
                            what is your exact issue
                            if you have a backup than post it with service tag
                            • viji90
                              • Jul 2017
                              • 22
                              • india
                              hi all, EDA50 LA-H271P Rev.1 bios need for my locked file pls
                              • rex98
                                • Feb 2023
                                • 1293
                                • Mandaue CEBU, Philippines
                                You MUST:
                                • viji90
                                  • Jul 2017
                                  • 22
                                  • india
                                  Service Tag do not know sticker got erased
                                  • rex98
                                    • Feb 2023
                                    • 1293
                                    service tag: CV15H53
                                    1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
                                    • to5it0
                                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                      by to5it0
                                      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                      I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                      This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                      I have opened the laptop and identified the main BIOS chip...
                                      10-24-2025, 01:35 AM
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
                                    • iZakre
                                      HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                      by iZakre
                                      Hello everybody!
                                      To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                      The thing is that I had installed TeamViewer and could log into the computer...
                                      02-19-2023, 02:27 PM
                                    • m1ch43lzm
                                      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                      by m1ch43lzm
                                      Hi everyone
                                      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                      There's also an extra OTP Secu.R...
                                      09-06-2025, 05:47 PM
                                    • Forest79
                                      by Forest79
                                      However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                      07-23-2023, 07:39 AM
