MSI 16j51 clean bios please
  • jaglion19
    • Oct 2017
    • 93
    • TURKEY
    msı 16j51 rev 1.0 clean bios help me
    I changed it to sr2c4. It stays at 14, cpu slight heat, please help, i need clean bios. They messed with the bios on it
    • 20720
    Re: 16j51 clean bios please
    you changed it to sr2c4 from what chip .What board did you take the sr2c4 from or did you buy it .
    • jaglion19
      • Oct 2017
      • 93
      • TURKEY
      I bought it from another msi device, the screen is slightly dark, the voltages are full. cpu gets hot 0,14 amper
        • 20720
        Re: MSI 16j51 clean bios please
        What is the full laptop model number, such as PE60 6QE
        • jaglion19
          • Oct 2017
          • 93
          • TURKEY
          Originally posted by smdflea
          what is the full laptop model number, such as pe60 6qe
          pe70 6qe-223tr
            • 20720
            MSI usually have full bios and EC`s at the support site - https://www.msi.com/Content-Creation...-6QE#down-bios
            • jaglion19
              • Oct 2017
              • 93
              • TURKEY
              I don't know how to clean
                • 20720
                A virgin bios from MSI doesn`t need cleaning,it has configured clean ME FW .
                • jaglion19
                  • Oct 2017
                  • 93
                  • TURKEY
                  Very thanks, I'm trying right away
                    • 20720
                    Theres a guide if you want to clean your bios insted,or post it if you really don`t want to flash the virgin bios..
                    https://www.badcaps.net/forum/showthread.php?t=88533
                    https://winraid.level1techs.com/t/gu...lization/31277
                    • jaglion19
                      • Oct 2017
                      • 93
                      • TURKEY
                      thanks ok
                      • jaglion19
                        • Oct 2017
                        • 93
                        • TURKEY
                        PE70 6QE help me please
                        need a good helper, device msi pe70 6qe, i changed sr2c4, merged bios via msi.com with updated me(11.8......). I made a clean me bios, the device worked, the image came, there is no promlem, I changed the msi text in the bios with the help of the hex editor, I made some additions, the image disappeared on the device, it did not come back,
                          • 20720
                          So it works fine with the virgin bios. The virgin bios doesn`t need the ME cleaning i mentioned that at post #8 .You changed the msi text,do you mean the logo ? ,and what other additions did you make.
                          • ignacio.ino27
                            • Feb 2019
                            • 21
                            • Argentina
                            Re: PE70 6QE help me please
                            You did something wrong. If the downloaded BIOS worked for you then dont do anything more like editing it, because you will mess it.
                            • jaglion19
                              • Oct 2017
                              • 93
                              • TURKEY
                              I wanted the name to be written next to the msi logo, this is the text "msi-sema ". I wrote it by saying add with the help of the hex editor. then I downloaded and wrote the new bios again, it didn't work, I changed it, still the same, no image
                              • jaglion19
                                • Oct 2017
                                • 93
                                • TURKEY
                                Since it doesn't work with virgin bios either, I downloaded the firmware update from the site, combined the me (11.8.......) in it. worked. then when i tampered with the bios it got corrupted, even if i write in virgin bios, reassemble it, there is no image
                                • HARAN963
                                  • Mar 2021
                                  • 45
                                  • FRANCE
                                  msi cx720 ms-17381 ver 1.0 -ver 1.05 bios
                                  I WANT BIOS BIN PLS
                                    • 20720
                                    I WANT BIOS BIN PLS
                                    Don`t hijack threads, start your own.
                                    • jaglion19
                                      • Oct 2017
                                      • 93
                                      • TURKEY
                                      Does anyone have the latest version running bios ec and kbc? tested
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • lrouw84
                                        by lrouw84
                                        Hi there,
                                        01-28-2023, 01:31 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
