MSI 16j51 clean bios please
  • jaglion19
    • Oct 2017
    • 113
    • TURKEY
    msı 16j51 rev 1.0 clean bios help me
    I changed it to sr2c4. It stays at 14, cpu slight heat, please help, i need clean bios. They messed with the bios on it
    • 22279
    Re: 16j51 clean bios please
    you changed it to sr2c4 from what chip .What board did you take the sr2c4 from or did you buy it .
    • jaglion19
      • Oct 2017
      • 113
      • TURKEY
      I bought it from another msi device, the screen is slightly dark, the voltages are full. cpu gets hot 0,14 amper
        • 22279
        Re: MSI 16j51 clean bios please
        What is the full laptop model number, such as PE60 6QE
        • jaglion19
          • Oct 2017
          • 113
          • TURKEY
          Originally posted by smdflea
          what is the full laptop model number, such as pe60 6qe
          pe70 6qe-223tr
            • 22279
            MSI usually have full bios and EC`s at the support site - https://www.msi.com/Content-Creation...-6QE#down-bios
            • jaglion19
              • Oct 2017
              • 113
              • TURKEY
              I don't know how to clean
                • 22279
                A virgin bios from MSI doesn`t need cleaning,it has configured clean ME FW .
                • jaglion19
                  • Oct 2017
                  • 113
                  • TURKEY
                  Very thanks, I'm trying right away
                    • 22279
                    Theres a guide if you want to clean your bios insted,or post it if you really don`t want to flash the virgin bios..
                    https://www.badcaps.net/forum/showthread.php?t=88533
                    https://winraid.level1techs.com/t/gu...lization/31277
                    • jaglion19
                      • Oct 2017
                      • 113
                      • TURKEY
                      thanks ok
                      • jaglion19
                        • Oct 2017
                        • 113
                        • TURKEY
                        PE70 6QE help me please
                        need a good helper, device msi pe70 6qe, i changed sr2c4, merged bios via msi.com with updated me(11.8......). I made a clean me bios, the device worked, the image came, there is no promlem, I changed the msi text in the bios with the help of the hex editor, I made some additions, the image disappeared on the device, it did not come back,
                          • 22279
                          So it works fine with the virgin bios. The virgin bios doesn`t need the ME cleaning i mentioned that at post #8 .You changed the msi text,do you mean the logo ? ,and what other additions did you make.
                          • ignacio.ino27
                            • Feb 2019
                            • 21
                            • Argentina
                            Re: PE70 6QE help me please
                            You did something wrong. If the downloaded BIOS worked for you then dont do anything more like editing it, because you will mess it.
                            • jaglion19
                              • Oct 2017
                              • 113
                              • TURKEY
                              I wanted the name to be written next to the msi logo, this is the text "msi-sema ". I wrote it by saying add with the help of the hex editor. then I downloaded and wrote the new bios again, it didn't work, I changed it, still the same, no image
                              • jaglion19
                                • Oct 2017
                                • 113
                                • TURKEY
                                Since it doesn't work with virgin bios either, I downloaded the firmware update from the site, combined the me (11.8.......) in it. worked. then when i tampered with the bios it got corrupted, even if i write in virgin bios, reassemble it, there is no image
                                • HARAN963
                                  • Mar 2021
                                  • 45
                                  • FRANCE
                                  msi cx720 ms-17381 ver 1.0 -ver 1.05 bios
                                  I WANT BIOS BIN PLS
                                    • 22279
                                    I WANT BIOS BIN PLS
                                    Don`t hijack threads, start your own.
                                    • jaglion19
                                      • Oct 2017
                                      • 113
                                      • TURKEY
                                      Does anyone have the latest version running bios ec and kbc? tested
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • lrouw84
                                        Asus vivobook s510ua bios changed to x510un
                                        by lrouw84
                                        Hi there,
                                        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                        01-28-2023, 01:31 PM
