Panasonic CF53 MK4 CF-532S74RMG
    replied
    Re: Panasonic CF53 MK4 CF-532S74RMG
    Originally posted by LenBios
    working but SN is like #16
    The DMI was copied from the bios at post #26 !!!
  • LenBios
    replied
    Originally posted by Maxpower3
    use winrar for my file
    first dump is original
    for second dump
    as SMDflea indicates, just remove a 0xA80328 for "smdflea file" or 0xA802EE for your original + AMITSEtup, it should work normally
    which lines are AMITSEtup?
    Thank you very much
  • Maxpower3
    replied
    this one is working with orig
    @Maxpower what did you change in this file from the original?
    Can you please send pictures which line have to fill zero etc?
    Thank you
    I removed all keys written in the dump 5B ..... AA 44 05 D8 60 6B
    can be written a hundred times with 00
  • LenBios
    replied
    Thank you
  • LenBios
    replied
    Originally posted by SMDFlea
    Try this one,it should be ok,with the SN ,key and mac address .
    replied
    thank you very much
    first file is working well
    from winzip the first one not working, the second one is working but has the SN like #16
  • LenBios
    replied
    winrar file is working well
    Winzip File= first file not working, second file is working but SN is like the post #16
  • Maxpower3
    replied
    thank you very much
    for second dump
    I used the bios from post #16 ,copied the DMI and GBE region and cleaned the ME FW .
  • LenBios
    replied
    Try this one .
    thank you but not working
  • LenBios
    replied
    If the SMD FLEA file doesn't work
    try those
    thank you very much
    replied
    you have cleaned well
    but there are still 2 occurrences
    0xA80328 :
    0xADAD8E :
    I forgot to zero fill the first one at 0xA80328 .I used the bios from post #16 ,copied the DMI and GBE region and cleaned the ME FW .I don`t think the other occurrence at 0xADAD8E would make any difference after setting bios defaults .
  • Maxpower3
    replied
    Originally posted by imranromi
    Try my file will see what happen.
    with your File no Panasonic Logo on Boot + same problem after defaults settings asking for password
    at the end of the string there is 01. Do not change it to 00. Otherwise Panasonic logo at boot will go away.
    https://mhhauto.com/Thread-Toughbook...804#pid1647804
  • Maxpower3
    replied
    try those
  • Maxpower3
    replied
    Try this one .
    0xA80328 :5B 02 B6 E8 11 59 6C FB C7 14 22 6F 7D AB D8 11 33 D4 8E 0D E9 1D 44 67 9F FC FA E3 55 34 B0 9C 0B 0C 66 4C C1 D3 1C C0 77 16 D2 A9 2D 3D 88 D0 E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B
    0xADAD8E :5B 48 B6 FE 11 42 6C 69 C7 57 22 6F 7D 64 D8 31 33 42 8E 3C E9 5C 44 30 9F AE FA 4F 55 4A B0 E4 0B 4F 66 12 C1 9C 1C 55 77 16 D2 A9 2D 3D 88 D0 E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B
    wait return of Lenbios
    with the file of post #16 which seems to unlock,
    we find written only once.
    0xADADC8 : 5B 48 B6 FE 11 42 6C 69 C7 57 22 6F 7D 64 D8 31 33 42 8E 3C E9 5C 44 30 9F AE FA 4F 55 4A B0 E4 0B 4F 66 12 C1 9C 1C 55 77 16 D2 A9 2D 3D 88 D0 E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B
    SMDFlea if not working maybe need to remove it ?
  • Maxpower3
    replied
    Originally posted by LenBios;
    what do you mean exactly? i do not understand
    many occurrence of the end of the old encryption key. (AA 44 05 D8 60 6B)
    OLD DECRYPT Xor Key: 5B 93 B6 26 11 BA 6C 4D C7 E0 22 74 7D 07 D8 9A 33 2E 8E C1 E9 54 44 E8 9F 7B FA 0E 55 A2 B0 35
    0B C9 66 5C C1 EF 1C 83 77 16 D2 A9 2D 3D 88 D0 E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B
    AMITSETUP: 5B AB B6 1F 11 CB 6C 7F C7 DE 22 8F 7D 4F D8 7D 33 73 8E 45 E9 5C 44 79 9F 89 FA 11 55 85 B0 2A 0B E3 66 27 C1 C6 1C 6D 77 16 D2 A9 2D 3D 88 D0 E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B
    in PADDING and NVAR :5B 02 B6 E8 11 59 6C FB C7 14 22 6F 7D AB D8 11 33 D4 8E 0D E9 1D 44 67 9F FC FA E3 55 34 B0 9C 0B 0C 66 4C C1 D3 1C C0 77 16 D2 A9 2D 3D 88 D0 E3 63 3E F7 99 8A F4 1D 4F B1 AA 44 05 D8 60 6B
    I find it weird
    replied
    Try this one .
  • imranromi
    replied
    Send me photo info like Serial,Model i will check again.
  • LenBios
    replied
  • imranromi
    replied
    please unlock this file thank you
  • LenBios
    replied
    looking with
    may be??
    more repetition in dump
  • AquaMan Ua
    by AquaMan Ua
    05-17-2025, 09:40 AM
  • aa10aa10
    Panasonic Toughbook CF-33 mk1 BIOS repair
    by aa10aa10
    Good day,
    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
    01-21-2025, 06:13 AM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • James Jackson
    Panasonic CF-20G0247VM BIOS Bad Flash Help
    by James Jackson
    I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
    Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
    05-01-2025, 11:28 AM
  • outsider
    Panasonic FZ-G1 MK5 - BIOS password returning
    by outsider
    Hello
    I removed the BIOS password thanks to the help of one of the friends of this forum.
    https://www.badcaps.net/forum/troubl...61#post3637661
    The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
    06-17-2025, 12:51 AM
