Lenovo G585 bios
  • AHmad_Salal
    Need BIOS Dump/ROM for Lenovo Thinkstation p500
    by AHmad_Salal
    Hello all,
    I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
    11-28-2023, 05:28 AM
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • mkdj
    Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
    by mkdj
    Dear all,
    I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
    Here the steps I have taken to fix the laptop:
    - downloaded latest BIOS from Lenovo Website...
    10-18-2025, 03:43 AM
