IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    • 20420
    Re: IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
    Originally posted by Ryzen1234
    Ryzen1234;1246821]can you help me
    this is my old bios
    Model Name : 82c6
    Serial Number: PF3A9JRS
    MTM: 82C600BLAU
    See post #109 ,everything you need is here in this thread.
    • rakiman
      • Nov 2015
      • 5
      • turkey
      #122
      Hello. There is a device with a motherboard code NM-D151 REV1.0. After updating the bios it stays on the black screen. It draws 0.6a. the fan spins and stops. Unfortunately, there is no label on the bottom of the computer with the serial number I have no chance to reach the serial number and mtm code. I made the DMI section between 1000 and 2FFF mentioned in the forum, but the situation did not change. Please help me...
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #123
        Try the bios in post #12, transfer "DMI section between 1000 and 2FFF" from your bios backup.
        Become a Badcaps supporter
        Thanks to all supporters.
        • rakiman
          • Nov 2015
          • 5
          • turkey
          #124
          I've tried. However, it doesn't. Is there any other solution
          • rakiman
            • Nov 2015
            • 5
            • turkey
            #125
            I had a problem after windows 11 bios update. I tried multiple bios but the problem was always the same. It was drawing a constant 0.6A current. Bios chip is broken. I changed it and the problem was solved. good work everyone
            • balobi
              • Jan 2015
              • 88
              • phillippines
              #126
              Re: Lenovo V15-ADA NM-D151 Rev 1.0
              Originally posted by purushottam karn
              try
              Many Thanks! Your files works!
              • lpraderi
                • Dec 2017
                • 30
                • Uruguay
                #127
                Same problem here, Lenovo 14-ADA PCB:NM-D151
                Dumped Bios an EC , followed directions on post #1 with latest update from web (e8cn39ww),
                added DMI data from dump = No POST/ black screen
                Erased EC with IO programmer, reboot = No POST / black screen
                reboot again and dump again EC to check data CRC of EC firmware.
                EC ROM image copied from BIOS address 0x2C8000 len 0x20000 to EC exactly.
                Will check with old versions posted in this thread (36 and 38) but it seems HW issue.
                • karamsms
                  • Aug 2023
                  • Paraguay
                  #128
                  Greetings to all,
                  I have my original BIOS that doesn't work
                  BIOS dump: Lenovo V15-ADA
                  SN: PF3JT6ZD
                  MTM: 82C7S03N00
                  Can anybody help me please?
                  Thanks in advance
                  • DanielDacko
                    • Mar 2015
                    • 325
                    • Macedonia
                    #129
                    Originally posted by karamsms
                    Greetings to all,
                    SN: PF3JT6ZD
                    MTM: 82C7S03N00
                    Thanks in advance
                    Factory image.
                    I don't provide help for people using CH341A and a clip.
                      • 20420
                      Greetings to all,
                      SN: PF3JT6ZD
                      MTM: 82C7S03N00
                      Thanks in advance
                      Use the bios from post #129 ,before you flash it transfer your serial number (DMI) from your backup to the new one,you can use the CopyDMI script at post #1 to do that, see the README text file.
                      • karamsms
                        • Aug 2023
                        • Paraguay
                        #131
                        I have already transferred my serial number (DMI) from my backup to the new one... manually with Tiny Hexer, the script didn't work for me... even so, I still don't have video.. not if any procedure of mine is wrong made..
                        • Cinek221
                          • Aug 2023
                          • Polska
                          #132
                          Good morning. I have a small problem laptop Lenovo ideapad 3 15ADA05 Model 81w1 NS PF2B06SQ MTM 81W1006YTPB. Black screen after bios update. the laptop came to me after another service and I do not know if it is the original bios from him in the connector. sorry for mistakes but i don't know english i use tlanslator
                          • peste
                            • 12314
                            • ROMANIA
                            #133
                            try post #12, #31... DMI is at post #1...
                            • audis78
                              • Aug 2023
                              • Lithuania
                              #134
                              Originally posted by onepic
                              I have patched it by myself, write it into the bios chip but still into the black screen... Can anyone verify it the patched BIOS it's should be ok with the data posted above? Thank you!
                              I make it in another way... Extracted BIOS.bin file from executable bios upgrade file simple with 7z, renaming extension to zip...
                              Then I make LENOVO bios dump from chip with all data on it. I made diff and see many differences in that files... I didn't know where which block in rom are... When I read DMI map file where are SERIAL NUMBERS and etc I just simple manualy made new bios.bin file and flashed it.
                              Flash I made from 5th or 6th try as bios chip verification was failed. (When I make bios update with executable file from Windows I see that there was errors too, but it was too late to stop it anyhow.
                              Now I have seems everything in its places, but not understand something...
                              Watched your photo... From address 0x20h to address 0x598h I have some variables or something, what I don't have in new bios chip... Can it be some SLIC info or something (I don't remember was there a SLIC or not)?
                              Maybe someone know more about bios map address of that machine?
                              • zcinciev
                                • Apr 2015
                                • Macedonia
                                #135
                                Hi guys.
                                I have this Lenovo NM-D151 it updated the bios and bricked not showing a picture. I tried a few from this forum but none worked. The board is GV451&GV551 Rev:1.0.
                                Any advice would be appreciated
                                  • 20420
                                  Originally posted by zcinciev
                                  Hi guys.
                                  Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                                  Provide a BIOS/EC dump if possible
                                  • loko
                                    • Aug 2020
                                    • 29
                                    • croatia
                                    #137
                                    Greetings to all members! I need help with the repair. It's a Lenovo IdeaPad3 V15-ADA laptop and its problem is the same that it works but there's nothing on the screen, caps and numlock keys also don't light up. I've programmed the eeprom with multiple bios files but nothing changes... The board was inspected and I found nothing, there is no short circuit on transistors or etc... Can anyone check this original bios of his if it is damaged in some way or etc... Thank you all for your help.
                                    No itegraded RAM.
                                    IdeaPad3 V15-ADA
                                    Model Name - 82C7
                                    S/N PF2ARM2M
                                    MTM82C7008ESC
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11363
                                      • Viet Nam
                                      #138
                                      No itegraded RAM.
                                      IdeaPad3 V15-ADA
                                      Model Name - 82C7
                                      S/N PF2ARM2M
                                      MTM82C7008ESC
                                      Get from Lenovo home page
                                      • loko
                                        • Aug 2020
                                        • 29
                                        • croatia
                                        #139
                                        Thanks! Now the laptop is up and running but after 5 seconds the screen start flickering and loosing picture, only white screen, any advice...?
                                        • loko
                                          • Aug 2020
                                          • 29
                                          • croatia
                                          #140
                                          Hi everyone.
                                          My laptop problem is solved for now. What I'm writing now is my experience with the mentioned motherboard, which does not mean that it might help someone else, and whoever does it will do so at their own risk.
                                          After I programmed the bios, the laptop worked for about 5 seconds, but then the image on the screen started flickering and then went to a completely white screen, which made me suspect a bad solder connection when the processor was heating up. The motherboard ended up in the oven and after baking the motherboard working perfectly...
                                            Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                          • Patriarxis
                                            Lenovo IdeaPad 3 14ADA05 dosen't turn on
                                            by Patriarxis
                                            Hello.
                                            I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
                                            It takes 0.027A and the power button flashing.
                                            All the voltages on the board are ok. 3.3, 5 etc.
                                            Also is charging the buttery .
                                            What else i can check?​
                                            05-26-2025, 01:03 AM
                                          • hotcrossedbuns999
                                            IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                                            by hotcrossedbuns999
                                            First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                                            Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                                            05-21-2025, 05:59 PM
                                          • pcwhiz24
                                            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                            by pcwhiz24
                                            Model: Lenovo IdeaPad 3 14ADA05 81W0
                                            S/N: PF2BZS7D
                                            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                            I already have a CH341A programmer...
                                            04-07-2025, 07:10 PM
                                          • Visual_vt
                                            Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                            by Visual_vt
                                            Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                            SSD and BIOS seems to be OK.
                                            Thank you....
                                            12-30-2024, 09:14 AM
