IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
Every donation made will go towards server fees and maintenance costs. -
V15-ADA Laptop (Lenovo) - Type 82C7
Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Greetings to all,
i have my originall bios which is not working, Black Screen and No Fan only white Power Led ON
BIOS Dump : Lenovo V14-ADA
SN: PF2J0G92
MTM: 82C6006CSP
Model Name: 82C6
Can please someone help me?
Thanks in advanceAttached Filesif you find these attachements useful please consider making a small donation to the site
V14-ADA Laptop (Lenovo) - Type 82C6
Lenovo V15-ADA Laptop
Model name: 82C7
SN: PF2BW4BC
MTM: 82C70041LM
BIOS FROM LENOVO WEB PAGE: laptops and netbooks :: lenovo v series laptops :: v15 adacontentdetail - Lenovo Support US
I was updating my laptop's BIOS. In the middle of the process, the screen went black, and unfortunately I restarted the computer. After that, it won't turn on anymore. I've read that it can be recovered if I reflash it. I've tried several methods but haven't been able to get the correct BIOS file. This community (GUIDE-How-to-extract-BIOS-from-Lenovo-BIOS-Update-Package-such-as-ATCN37WW-exe - English Community - LENOVO COMMUNITY) explains how to extract the correct BIOS from the original file on the Lenovo website, but it didn't work for me. Hex files and assembly code aren't my thing.
Finally, I understand that if I get the basic BIOS file and run it from a USB drive, I have the possibility of recovering my laptop, just as mentioned in this guide (I-need-to-recovery-corrupted-BIOS-for-LENOVO-YOGA-500-15IHV - English Community - LENOVO COMMUNITY). One last question: The BIOS file must have an fd, bin, or some special extension to run correctly. Please help me.Comment
AS mention in the guide : .binHi everyone,
Model name: 82C7
SN: PF2BW4BC
MTM: 82C70041LM
if you can't have .bin...than post your old dump and the serial and someone will help youComment
Hi All
I have an IdeaPad 3-17ADA05 -
Serial PF206XN8
Model 81W2 -
MTM 81W20056FR
that presented errors that seeme d to indicate onboard RAM issue.
I tried to disable the onboard ram following the instructions here [ solder-desolder resistors] but had no boot
I copied the DMI info to a downloaded Bios Bin as per this link
https://www.badcaps.net/forum/troubl...pt#post1214739
and got a boot ,but the system crashes with ACPI error after 5 minutes every time.
Attached is the original Bios Dump and the one that sort of worked
Thanks in advance
you have everything you need at post #29..Hi All
Serial PF206XN8
Model 81W2 -
MTM 81W20056FR
Thanks in advance
https://www.badcaps.net/forum/troubl...-15ada05/page3
for DMI information..
the bios from post # 29 is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
Every donation made will go towards server fees and maintenance costs.Comment
Hi Peste,
Thanks a lot for you answer, I will check right awayyou have everything you need at post #29..
Does anything needs to be changed in the bios if i disable the onboard ram via the resistors ? I could not be sure of it.
Here is latest bios with your DMI information, but the problem isn't in the bios, it's in the CPU soldering. Reflow the CPU. This is known issue on those thin Lenovo boards.Hi All
Serial PF206XN8
Model 81W2 -
MTM 81W20056FR
Thanks in advance
I don't provide help for people using CH341A and a clip.Comment
I flashed the bios of my lenovo 15ADA05 with the latest bios available on lenovo. Unfortunately, after the installation procedure with continuous sounds, I had a black screen and tried to restart. Then the computer remained with a black screen on reboot and the fan running normally. Impossible to launch the bios. So I dismantled the computer and tried flashing with cha341. I was able to read the current bios and saved it. I tried to rewrite on it with a bios found on bios archive but it doesn't work.
Here is the information to help me get a dmi and a blank bios to remake a bios with a custom dmi:
Ideapad 3 15ADA05
MODEL name: 81w1
SN: PF3NTMCG
MTM: 81W1002GFR
ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
you have everything you need at post #1,and12...Hello,
Ideapad 3 15ADA05
MODEL name: 81w1
SN: PF3NTMCG
MTM: 81W1002GFR
Hi everyone
i have a lenovo V15-ADA
Model 82C7
Serial PF2CZ1AN
MTM 82C7S00B00
after updating the bios the LEDs light up, the fan spins but nothing else happens, i saved my bios can you help me?Attached Filesif you find these attachements useful please consider making a small donation to the site
HereAttached Filesif you find these attachements useful please consider making a small donation to the site
This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 05:00 AM
by PatriarxisHello.
I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
It takes 0.027A and the power button flashing.
All the voltages on the board are ok. 3.3, 5 etc.
Also is charging the buttery .
What else i can check?05-26-2025, 01:03 AM -
First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...-
Channel: BIOS Requests ONLY!
by pcwhiz24Model: Lenovo IdeaPad 3 14ADA05 81W0
S/N: PF2BZS7D
I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
I already have a CH341A programmer...-
by Visual_vtLenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
SSD and BIOS seems to be OK.
Thank you.... - Loading...
