IdeaPad 3 14ADA05/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
  • peste
    • 13915
    • ROMANIA
    #421
    Originally posted by MIRROR6866
    Please help. The machine turns on, but there is no image. I have attached the original content and bios. thanks
    IdeaPad 3 15ADA05
    Model:81W1
    SN:pf262c6n MTM:81W10033SP
    read the post above..
    • fun_dogg
      • Nov 2025
      • Magyarország
      #422
      Hello All!
      I've IdeaPad 3 15ADA05 Laptop - Type 81W1
      S/N: PF2972BX
      GS550 logo on left panel
      GS450&GS550&GS750 NM-C821 REV 1.0
      At first it sometimes powered on and showed display, but often froze even in BIOS or just goes black screen after a few minutes on screen. When it reached the Windows 2 times PIN screen, the display went black.
      After that it only powered on with a black screen.
      I flashed NM-C821 DUMP.BIN, and the TPM reset screen appeared right away.
      Then it froze at the Windows logo then restarted and froze with an IRQL_NOT_LESS_OR_EQUAL BSOD.
      On the 2nd boot it black-screened again, and from the 3rd or 4th attempt there was no display at all.
      Wierd that I pluged charger in laptop turned on without press power button..
      Now, on AC power without battery, the power LED blinks, CPU fan spins, but there’s no display.
      After reflashing the same BIOS again, on first power-on the CPU fan spins briefly then stops (power LED stays on);
      on the 2nd boot the fan spins continuously after about a minute;
      and since then, it always spins but still no display.
      I’ve also tried the latest forum BIOS E8CN41WW.bin, same result but now when I plug AC power in laptop wont turn on automatically.
      Flashed with NeoProgrammer 2.2.0.10 + CH341A Pro (black edition with green 1.8 V adapter).
      Chip: Winbond W25Q64JW.
      Verify always OK, no errors.
      Any ideas what could be wrong?
      • peste
        • 13915
        • ROMANIA
        #423
        https://www.badcaps.net/forum/troubl...ed#post3718145
        you have everything you need at post #14...
        The bios chip must be unsoldered from the board before writing or reading..
        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
        solder wires between the programmer and the bios chip..
        you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
        • Mrkennyd
          • Jun 2023
          • France
          #424
          I have a Lenovo IdeaPad 3 17IADA05 (81W2) with a BIOS problem.
          S/N : PF2LSSVK
          The laptop powers on, the fan runs and the screen backlight turns on, but there is no display, no Lenovo logo and no POST.
          and I cannot enter BIOS with F2 / Fn+F2.
          I now have a dump from the original SPI chip and I’m hoping someone can help check, repair or rebuild it so the laptop can boot again.
          Thanks in advance.
          • peste
            • 13915
            • ROMANIA
            #425
            S/N : PF2LSSVK
            Thanks in advance.
              Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
              09-07-2024, 05:00 AM
            • Patriarxis
              Lenovo IdeaPad 3 14ADA05 dosen't turn on
              by Patriarxis
              Hello.
              I have a Lenovo IdeaPad 3 14ADA05 that it dosen't turn on.
              It takes 0.027A and the power button flashing.
              All the voltages on the board are ok. 3.3, 5 etc.
              Also is charging the buttery .
              What else i can check?​
              05-26-2025, 01:03 AM
            • hotcrossedbuns999
              IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
              by hotcrossedbuns999
              First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
              Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
              05-21-2025, 05:59 PM
            • pcwhiz24
              Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
              by pcwhiz24
              Model: Lenovo IdeaPad 3 14ADA05 81W0
              S/N: PF2BZS7D
              I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
              I already have a CH341A programmer...
              04-07-2025, 07:10 PM
            • Visual_vt
              Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
              by Visual_vt
              Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
              SSD and BIOS seems to be OK.
              Thank you....
              12-30-2024, 09:14 AM
