Dell Latitude 5400 Bios password
  • ACHRAFJIRANI
    • Apr 2018
    • 65
    • MOROCCO
    #181
    Re: Dell Latitude 5400 Bios password
    Originally posted by ACHRAFJIRANI
    dell latutude 5400 password 8FC8
    unlock pls
    someone help me pls
    • Mazorca
      • Jan 2017
      • 463
      someone help me pls
      There should be another chip, 8MB big. Look for numbers 64 on the face of the chip, like W25Q64BV.
      • Mazorca
        • Jan 2017
        • 463
        Originally posted by levitor
        Still locked bro.
        Try this, not sure if with hoaca388's file or not. Try it first with original 16MB. Set bios settings to default on first boot.
        • ACHRAFJIRANI
          • Apr 2018
          • 65
          • MOROCCO
          #184
          Originally posted by mazorca
          there should be another chip, 8mb big. Look for numbers 64 on the face of the chip, like w25q64bv.
          • Mazorca
            • Jan 2017
            • 463
            Try it now.
            • ACHRAFJIRANI
              • Apr 2018
              • 65
              • MOROCCO
              #186
              Originally posted by Mazorca
              Try it now.
              thinks bro unlocked
              • xplodpg
                • Oct 2016
                • 30
                • Polska
                #187
                Hi. I need unlock password bios.
                1PZQ0Z2-8FC8
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12118
                  #188
                  1PZQ0Z2-8FC8
                  Here
                  • Verlengsnoer
                    • Sep 2016
                    • 110
                    • Netherlands
                    #189
                    hope someone can unlock this unit, code on bios-pw(dot)org diddnt work.
                    thanks in advance
                    • hardware1
                      • Sep 2021
                      • 2943
                      • N/A
                      #190
                      thanks in advance
                      Try this one.
                      all donations are welcome,
                      • Verlengsnoer
                        • Sep 2016
                        • 110
                        • Netherlands
                        #191
                        Try this one.
                        it works thanks
                        i was thinking that it wasnt working, because after flashen the laptop turns on, but black screen and fan on max speed.
                        after a minute of 7 it showed up the bios to enter the service tag, after filling in the service tag it takes again around 7 minutes to boot and update things, but after that it works fast en normal again
                        • AHiggins72
                          • Oct 2022
                          #192
                          I have a Dell Latitude 5400 with a EDC41 LA-G891P Rev 1.0 board, can anybody point me in the right direction.
                          The BIOS is locked, and I'm looking to replace the BIOS/firmware to unlock the BIOS, the problem I have I don't know which IC/Flash holds the Intel Managment code. I've backed up UC6 (W25Q128JV) located next to the CMOS battery but when I save flash memory using a flash reader the output is a 16MB bin file. I was expecting a 32MB file now if load the 16MB bin file into UEFITool it only lists the UEFI section not the Intel section.
                          So my question is am I reading/saving to/from the correct chip.
                          many thanks
                          • AHiggins72
                            • Oct 2022
                            #193
                            Silly question from a very newbie, do you know which IC on a Dell Latitude 5400 stores the uefi code
                            many thanks
                            • volinakis
                              • Jan 2021
                              • 2805
                              • N/A
                              #194
                              many thanks
                              use ME Analyzer. it should be another chipset of 8MB (eg. w25q64) containing Intel image.
                              • lezsimply
                                The Wanderer
                                • 655
                                • Philippines
                                #195
                                Hi, can anybody remove password from this one. Dell latitude 5400 LA-G892P REV. 1.0. I attach bin file. thanks very much.
                                • hardware1
                                  • Sep 2021
                                  • 2943
                                  • N/A
                                  #196
                                  Here's your unlocked file, try it.
                                  • lezsimply
                                    The Wanderer
                                    • 655
                                    • Philippines
                                    #197
                                    @hardware1 tried the file and i got no power. amber light stays on when i press power button. Is this bios issue? thanks for reply. Laptop issue is password protected
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12118
                                      #198
                                      Recheck your chip flash procedure.
                                      • kenzakie
                                        • Feb 2020
                                        • 6
                                        • philippines
                                        #199
                                        please help me unlock this bios model 5400 8thgen
                                        board id EDC41 LA-G891P
                                        • deep_bks
                                          • Apr 2015
                                          • 77
                                          • india
                                          #200
                                          somebody help me unlock thankkk
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 5400 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...
                                            09-06-2024, 12:13 PM
