¡¡PLEASE!! I NEED BIOS and DUMP of positive bgh ql 300 board 6-71-w3100-d03a
  • tesla2020
    • Apr 2021
    • 14
    • Argentina
    I need help from the most pro in Hardware. i am checking a computer a positive bhg ql 300 the board is
    of the clevo brand the plate number is 6-71-w3100-d03 it turns out that I press the power button and it does not do it absolutely
    nothing I check tension in the button and there is no this tension is 3.3VS this is enabled after the activation of SusC and susB
    It turns out that these signals are not present either, they are enabled with the signal DD_ON signal that comes from the ITE 8518E
    Should this signal be present just by energizing the equipment? In the power-on sequence diagram this is
    first and seems to be independent
    It does not cause me to have a problem with the IT because it is sending a HIGH in the LED_ACIN signal that goes to the led that indicates that the charger is connected
    I think it could be because of the EC memory? what do you think? any idea is welcome Thanks in advance
    PS: if someone has the bios and the ec, I am very grateful I leave the link where you can download the diagram of this notebook
    https://drive.google.com/file/d/1S2j...ew?usp=sharing
  • Bonzas
    • 471
    • Indonesia
    Re: ¡¡PLEASE!! I NEED BIOS and DUMP of positive bgh ql 300 board 6-71-w3100-d03a
    Bios look same with your board
    https://www.badcaps.net/forum/showthread.php?t=77262
    • tesla2020
      • Apr 2021
      • 14
      • Argentina
      thanks you very mach i will try it
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Captaincrap420
        Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
        by Captaincrap420
        Hi, I hope this is the right place to post this. This is my first post on this forum.
        A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
        This bios dump is straight from the chip, nothing has been...
        11-29-2024, 05:40 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • grimacelord
        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
        by grimacelord
        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
        Motherboard model number: DA0PAMB46A1 REV: A
        Secondary motherboard model number: 0PAB
        SKU: 685K4UA
        Serial number is: 5CD3223BJP
        Recently reflashed this laptop with latest BIOS and once...
        05-07-2024, 08:06 AM
