HP EliteBook 855 G7 Bios unlock
  • filewalker
    • Dec 2020
    • 16
    I also got a HP Elitebook 855 G7 with two 32MB Chips. Can someone unlock them for me?
    Thanks in advance
      SMDFlea commented
      Editing a comment
      Maybe,if you post the serial number
      You MUST:
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • filewalker
    • Dec 2020
    • 16
    Thanks in advance
    The serial number is: 5CG11314N8
    ProdID: 3E780AV
    • rex98
      • Feb 2023
      • 1278
      • Mandaue CEBU, Philippines
      #43
      Thanks in advance
      only flash this Ec do not touch the main.
      you didn't mention absolute lock so this is just for bios password removal.
      • filewalker
        • Dec 2020
        • 16
        Thanks, it worked great.
        • XIII
          XIII
          • Mar 2024
          • 22
          • Tunisia
          #45
          Hi, I have an HP 855 g7 EliteBook with an admin bios password, can anyone please unlock it for me .? In case it's impossible to unlock it at least I want to obtain the password at if possible or the s/n and the mac adress for me in order to for me to reprogram it again with an other modified bios that i have, thanks in advance! the main problem after flashing the new bios that I found in this website is that I get an "Endpoint Security Controller Problem" error when the laptop starts, thank you for your help
          • hoaca388
            Badcaps
            • Jan 2022
            • 11741
            #46
            File corrupted.
            • XIII
              XIII
              • Mar 2024
              • 22
              • Tunisia
              #47
              how about this file ? i have saved many copies thank for your help tho
              • hoaca388
                Badcaps
                • Jan 2022
                • 11741
                #48
                You should reread your bios chip at least 3 times. A successful backup file usually has a capacity in MB, not KB.
                • XIII
                  XIII
                  • Mar 2024
                  • 22
                  • Tunisia
                  #49
                  Hi, the laptop has 2 chips, i concluded that both chips have the same bios file otherwise, this is the file from the first chip can you please take a look at it?
                • XIII
                  XIII
                  • Mar 2024
                  • 22
                  • Tunisia
                  #50
                  Hi, the laptop model is HP ELITEBOOK 855G7
                  the serial number is SN# 5CG1442GX8
                  the product ID is 3E778AV
                  can you please unlock the bios password for me? this is the second chip bios, since the other one is corrupted I think, I just need the password removed or given to me, otherwise if possible I have a bios that I obtained from this website but I get HP ENDPOINT SECURITY ERROR once I use it.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11741
                    #51
                    Unlocked
                    • XIII
                      XIII
                      • Mar 2024
                      • 22
                      • Tunisia
                      #52
                      Originally posted by hoaca388
                      Unlocked
                      Thank you so much it worked like a charm, I appreciate your help!
                      • spacez
                        • Nov 2023
                        • 54
                        • FR
                        #53
                        hello please unlock this one HP ELITEBOOK 855 G7
                        SN : 5CG1297NHO
                        PROID : 3E779AV
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11741
                          #54
                          SN : 5CG1297NHO
                          PROID : 3E779AV
                          HP EliteBook 855 G7 Notebook PC
                          CT Number_6LGWV08TZF95VH
                          Serial_5CG1297NH0
                          Product_3E779AV
                          Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEnW.yG
                          Build Id_20WWLDDT601#SABF#DABF
                          • dinocool
                            • Jan 2022
                            • 3
                            • Poland
                            #55
                            SN : 5CG1459SMY
                            PROID : 3E779AV
                            Thanks​
                            • rex98
                              • Feb 2023
                              • 1278
                              #56
                              SN : 5CG1459SMY
                              PROID : 3E779AV
                              first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                              use BCU. you can permanently disable Absolute lock in BCU.
                              here's your DMI:
                              Serial Number: 5CG1459SMY
                              Product #/SKU: 3E779AV
                              CT Number: PKBVF00WBFW18J
                              Description: HP EliteBook 855 G7 Notebook PC
                              BuildID: 20WWLDDT601#SAKD#DAKD
                              Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfPguhKhkjhk8mEmVnW.T2
                              MAC Address : C8:5A:CF:7A:5A:B3​
                              • SBB01
                                • Dec 2024
                                • 3
                                • Costa Rica
                                #57
                                I have a 855 G7 with a factory bios lock on WLAN. Any chance to remove that with a differrent BIOS? The WLAN slot receives a wlan card and activates the bluetooth but does not show any WLAN adapter. No WLAN options at all in the BIOS.
                                Serial: 5CG1248Z0M
                                P/N 641J5E8R
                                Thanks in advance for the help
                                • peste
                                  • Dec 2016
                                  • 12821
                                  • ROMANIA
                                  #58
                                  Serial: 5CG1248Z0M
                                  P/N 641J5E8R
                                  post the original contents of the bios chip..
                                  • SBB01
                                    • Dec 2024
                                    • 3
                                    • Costa Rica
                                    #59
                                    Sorry for the ignorance... how do I do that?
                                    • peste
                                      • Dec 2016
                                      • 12821
                                      • ROMANIA
                                      #60
                                      you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                                      • STKR123
                                        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                        by STKR123
                                        Greetings badcaps community,
                                        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                        I learned that desoldering...
                                        10-29-2024, 06:03 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • clrscr
                                        Need unlock bios hp elitebook 835 G11
                                        by clrscr
                                        please help me unlock bios password hp elitebook 835 G11
                                        S/N: 5CG50434RD
                                        thanks!...
                                        06-04-2025, 09:38 PM
                                      • Guest
                                        Elitebook 850 G5 BIOS bricked
                                        by Guest
                                        I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                        I assume the BIOS update failed, so I searched for the BIOS chip.
                                        I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                        However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                        Can the corrupted...
                                        03-24-2025, 01:21 AM
                                      • Bharath Ram
                                        HP Elitebook MT45 Bios Unlock
                                        by Bharath Ram
                                        Hi
                                        Can someone please unlock the attached bios file
                                        Laptop: HP MT45
                                        Chip: W25Q256JV
                                        Thanks...
                                        06-21-2025, 09:09 PM
