HP 240 G8 Corrupt Bios
  • hdd00
    • Jan 2015
    • 32
    • Romania
    Hi guys
    I have a HP 240 G8 laptop which start up , says Bios need recovery, after that goes to rewriting bios and finaly it says all is good, success.
    BUT.
    After restart a message saying that the bios needs recovery appears and all the above steps are run again and so on ina continuos loop...
    I searched the net but no bios dump for this board exists.
    Can anyone help me with a correct dump or someone can look at the dump?
    Here are the details:
    Board : HEDWIG01-6050A3158801-MB-A02
    Lapop model: HP 240 G8
    Bios chip: W25Q128JVPQ
    Board ID : 0868A
    Here is my original bios:
  • peste
    • Dec 2016
    • 13678
    • ROMANIA
    Re: HP 240 G8 Corrupt Bios
    Originally posted by hdd00
    Hi guys
    BUT.
    Board ID : 0868A
    https://forum.laboneinside.com/viewtopic.php?t=12025
    • hdd00
      • Jan 2015
      • 32
      • Romania
      Will test and report here how it ends.
      Rgds
      • hdd00
        • Jan 2015
        • 32
        • Romania
        Hi
        It works , finally, but does anyone know where/how to modify DMI info? Now the model is HP 14s-cf3xxx. I want to put all corect info back.
        Rgds
        • peste
          • Dec 2016
          • 13678
          • ROMANIA
          Hi
          Rgds
          try this ..
          https://www.youtube.com/watch?v=9T57ktw8n3Y
            • 22012
            Hi
            Rgds
            Copy the dmi and win key from the old bios using a hex editor
            D 481000 - 482FFF (Length 2000)
            W A9E000 - A9E03F (Length 40)
            • hdd00
              • Jan 2015
              • 32
              • Romania
              Hi...Thanks for the DMI info....
              Unfortunately with this dump it takes 2-3 minute for the image to appear at start up , reset and even at "save and exit" from bios .....I think it's too long and is somehow unacceptable....
              I will search the net or wait until a compatible dump for this mainboard appears...
              If anyone know a good dump for this , please let me know.
              Thanks again
              Rgds
              • hdd00
                • Jan 2015
                • 32
                • Romania
                Finally a working bios dump for this board.....It's a clean dump extracted from HP bios update executable and inserted the DMI and Win info...
                Now the image appears in time and the boot is fast as it should be.
                Thanks to all.
                Rgds
                • eltato17
                  • Dec 2021
                  • españa
                  Hi, I'm from Spain, I use google translator, I'm sorry, you can put a photo of the bios, and with which programmer I have the same problem but I don't know if the bios is winbon, and if the programmer works for me
                  USB Programmer CH341A 24/25 Serial Graveur BIOS Writer SPI Flash + de bord U6N2
                  • LeMMino18
                    • Mar 2021
                    • 10
                    • Philippines
                    Thanks to all.
                    Rgds
                    Now this is something else thanks for sharing
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                      by haitham sharabati
                      Hello engineers 😀,
                      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                      💀 Problem:😅
                      - Device shows “Administrator Password”...
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
