DAG35MMB8C1 rev C
  • lefos
    • Nov 2013
    • 321
    • Greece
    DAG35MMB8C1 rev C
    This laptop turns ON for several seconds then turns OFF.
    Attached is the original BIOS, I wondered if someone can check it or provide a working one.
    Wanted to start from the easy part first
    Thanks in advance!
    • 21304
    Re: DAG35MMB8C1 rev C
    post the full laptop model number
    • lefos
      • Nov 2013
      • 321
      • Greece
      It is a 15-bc400nv
        • 21304
        bios plus dmi .
        • peste
          • Dec 2016
          • 13072
          • ROMANIA
          Originally posted by lefos
          It is a 15-bc400nv
          Bios extracted from the HP site update..the laptop has three variants of your bios is 084F7
          DMI 220000-2210FF
          KEYWIN 646000-64603F
            • 21304
            DMI 220000-2200FF
            The DMI is 220000 - 2210FF ,the featurebyte is at the end
            • peste
              • Dec 2016
              • 13072
              • ROMANIA
              yes you are right ..I have changed ..
                • 21304
                Its easy to forget about the featurebyte, it catches me out sometimes,then have to desolder the bios again, i don`t like using hp`s DMI tools
                • lefos
                  • Nov 2013
                  • 321
                  • Greece
                  Guys thanks a lot for your help.
                  Tried SMDFlea's file but I have the same problem so unfortunately the problem might not be BIOS related.
                  Similar problem was from chipset.
                  I guess my dump was OK btw if someone wants to give it a try.
                  Thanks guys once again
                  • claudiunew
                    • Sep 2022
                    • 3
                    • Romania
                    HP dag35mmb8c1 BIOS needed
                    Hi, can you please help me to get a BIOS for HP Pavilion 15
                    Motherboard info :
                    DAG35MMB8C1 REV C
                    • peste
                      • Dec 2016
                      • 13072
                      • ROMANIA
                      Re: HP dag35mmb8c1 BIOS needed
                      Motherboard info :
                      DAG35MMB8C1 REV C
                      read this..
                      always post the bios and the full name and model of the laptop when you make a bios request..
                      • ormcra
                        • Jan 2016
                        • 14
                        • madrid
                        Bios file for DAG35MMB8C1 REV C
                        Hi friends.
                        Need working backup bios + ec for this machine:
                        HP 15-BC401NS
                        DAG35MMB8C1 REV C
                        CPU: Intel SR3LA - I5 -8th
                        GPU: N17P-G0-A1
                        Tried more bios files and not work.
                        Startup good but not image.
                        Power Consumption in Supply: 0.990 ma.
                        Al Rails are ok of voltage.
                        Thanks in advanced.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11986
                          Re: Bios file for DAG35MMB8C1 REV C
                          Rule : https://www.badcaps.net/forum/showthread.php?t=103570
                          Any donations to badcaps are welcome, click this link to donate. Thanks to all the supporters----------------------------------------------------------------------------------------------------------------------------------------------------------------
                          • baata1
                            • Nov 2022
                            • 17
                            • france
                            HP Pavilion bios file Laptop model: 15-bc402nf
                            Hello, I need HP Pavilion bios file Laptop model: 15-bc402nf.
                            Motherboard reference: DAG35MMB8C1.
                            Thank you so much.
                              • 21304
                              Re: HP Pavilion bios file Laptop model: 15-bc402nf
                              Thank you so much.
                              Serial number, backup ?
                              • Stephen
                                MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                by Stephen
                                MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                03-15-2024, 09:37 AM
                              • ferah831208
                                Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                by ferah831208
                                Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                03-18-2025, 01:18 AM
                              • www
                                LG L192WS-BN backlight turns off after 1 second
                                by www
                                I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                03-24-2024, 05:26 PM
                              • zklgfs
                                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                by zklgfs
                                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                08-11-2025, 02:14 PM
                              • andrhouseolly
                                Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                by andrhouseolly
                                Hi.
                                I kindly ask you to help me solve the problem.
                                Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                The board turns on, there is no image.
                                Read more. When the power supply is connected, the front panel indicators light up briefly.
                                When you press the power button, the button indicator lights up. The board works
                                there is no image, there is no matrix initialization, there is no image on HDMI.
                                When turned on, the fans do not spin, but when they warm up they start spinning.
                                When you turn off the button, the fans spin up to full speed for a short...
                                05-11-2024, 03:14 PM
