HP Elitebook 850 G5 Which Chip is for Bios and which for EC ? Pictures existing
  • Blackcoiin
    • Feb 2019
    • 55
    Hello Guys,
    Here I got a HP Elitebook 850 G5.
    The Bios is locked. But before unsoldering the Chip i need to know, which Chip is what. I got 2 Chips on the Motherboard. One of them is small and the orther is bigger. Which one i need to unsolder for unlock the Bios ?
    Can Please someone help me ?
    Thank you Guys !
  • sourcebf
    • Jul 2016
    • 433
    • N/A
    Re: HP Elitebook 850 G5 Which Chip is for Bios and which for EC ? Pictures existing
    the big one 25Q256JV
    • Blackcoiin
      • Feb 2019
      • 55
      Thank you very much for the fast answering !
      Do i just need to unsolder them to unlock the Bios Password ?
      • remtep
        • Jun 2021
        • 6
        • stockton
        First thank yous for your time and knowledge, It is much appreciated
        I have the same problem with my HP Elitebook 850 g5, I believe I have to take a bios dump from two chip if so are they the same two chips in the photo above
        • D4B1_
          • Jun 2023
          • Spain
          I currently have the same board with the bios password I don't have. And I am looking for a solution. I have seen that the board has 3 winbond chips and it really makes me doubt which one I have to replace or remove.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            if the problem is only the Administrator password dump the 16Mb chip only and use RCUnlocker to edit the file and remove the password.
            https://www.badcaps.net/forum/showthread.php?t=103526
            Become a Badcaps supporter
            Thanks to all supporters.​
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
              by SMDFlea
              Bad...
              09-02-2021, 04:40 PM
            • JoWed
              Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
              by JoWed
              Hello Community,
              I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
              07-01-2025, 09:32 AM
            • Azurain
              Elitebook 840 G5 Bios Chip Soldering Question
              by Azurain
              I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
              Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
              04-14-2023, 06:58 PM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
