HP Elitebook 850 G5 Which Chip is for Bios and which for EC ? Pictures existing
  • Blackcoiin
    • Feb 2019
    • 54
    Hello Guys,
    Here I got a HP Elitebook 850 G5.
    The Bios is locked. But before unsoldering the Chip i need to know, which Chip is what. I got 2 Chips on the Motherboard. One of them is small and the orther is bigger. Which one i need to unsolder for unlock the Bios ?
    Can Please someone help me ?
    Thank you Guys !
  • sourcebf
    • Jul 2016
    • 431
    • N/A
    Re: HP Elitebook 850 G5 Which Chip is for Bios and which for EC ? Pictures existing
    the big one 25Q256JV
    • Blackcoiin
      • Feb 2019
      • 54
      Thank you very much for the fast answering !
      Do i just need to unsolder them to unlock the Bios Password ?
      • remtep
        • Jun 2021
        • 6
        • stockton
        First thank yous for your time and knowledge, It is much appreciated
        I have the same problem with my HP Elitebook 850 g5, I believe I have to take a bios dump from two chip if so are they the same two chips in the photo above
        • D4B1_
          • Jun 2023
          • Spain
          I currently have the same board with the bios password I don't have. And I am looking for a solution. I have seen that the board has 3 winbond chips and it really makes me doubt which one I have to replace or remove.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            if the problem is only the Administrator password dump the 16Mb chip only and use RCUnlocker to edit the file and remove the password.
            https://www.badcaps.net/forum/showthread.php?t=103526
            Become a Badcaps supporter
            Thanks to all supporters.​
              by SMDFlea
              Bad...
              09-02-2021, 04:40 PM
            • Azurain
              Elitebook 840 G5 Bios Chip Soldering Question
              by Azurain
              I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
              Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
              04-14-2023, 06:58 PM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
            • thxd43
              Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
              by thxd43
              Hello, first of all, excuse me, I am using the translator, English is not my native language.
              I have a Lenovo ideapad 330S - 14IKB laptop.
              The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
              02-23-2023, 08:37 PM
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
