NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
  • hoaca388
    replied
    Originally posted by faisalhabib
    sir what can i do now?
    please help me
    i attached laptop casing and mb vedio, please see this vedio
    https://www.badcaps.net/forum/troubl...-mb-a01/page31
Name:	2025-06-03 14_33_40-hp 840 g6 6050A3022501-MB-A01 - Badcaps.png
  • faisalhabib
    replied
    Originally posted by hoaca388
    You don't have a video because these files are from HP EliteBook 840 G5
    please help me
  • hoaca388
    replied
    Re: NEED BIOS FOR HP EliteBook 840 G6
    SN: 5CG9387SSY
    mb MODEL 6050a2945601-mb-a01
    SIR HELP ME PLEASE
    NO DISPLAY PROBLEM
    EC FILE OTHER ENGINNER CHANGE, I DONT KNOW ITS ORGINAL OR NOT
    MAIN FILE ORGINAL FILE
    I ATTCHED MY FILE
    I WRITE MANY MAIN FILE, BUT FAN FULL SPEED & NO DISPLAY
  • Karol Wu
    replied
    Originally posted by Karol Wu
    For those who need a clean BIOS (no passwords, factory defaults, without DMI) for the HP EliteBook 840 G5 (6050A2945601-MB-A01):
    Since nobody here could help me, I turned to Wrong Chip on YouTube (link below). Here's my experience for others facing similar issues:
    1. These BIOS files work—I successfully flashed both by CH341A (modded from 5V for 3.3V!) by Neoprogrammer on Windows:
      • 32MB chip (W25Q256JVEIQ)
      • 16MB chip (W25Q128JVPQ)
    2. My W25Q256JVEIQ BIOS was corrupted (physical damagel). You can use my files, but they do NOT include DMI data (you have mine attached for serial 5CG013DSCM)
    3. DMI Solution: Wrong Chip provided my DMI data, which I injected using the method shown in this video:
    4. Boot Failure? Another reason my laptop wouldn't turn on was accidentally removing the 22-ohm resistor. If your motherboard is unresponsive, double-check all resistors!
    Click image for larger version  Name:	HP840G5.jpg Views:	52 Size:	156.9 KB ID:	3647994
    Reupload 2x missed packages to flash as new BIOS
    My DMI if you don't have yours you can try as above YouTube movie after start
    Serial Number: "5CG013DSCM" SKU Number: "2FA66AV"
    Board CT Number: "PGWHT00WBDH1KY"
    Product Name: "HP EliteBook 840 G5"
    BuildID: "17WWCSDT601#SABD#DABD"
    Feature Byte: "3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPfXhKhkjh.fm"
    MAC Address: "10-62-E5-56-A7-0D"
    commented on 's reply
    is your caps lock stuck on - you should ask for a solution to this?
  • faisalhabib
    replied
    SN: 5CG9387SSY
    SIR HELP ME PLEASE
    NO DISPLAY PROBLEM
    I ATTCHED MY FILE
  • Karol Wu
    replied
    2. My W25Q256JVEIQ BIOS was corrupted (physical damagel). You can use my files, but they do NOT include DMI data (you have mine attached for serial 5CG013DSCM​)
  • nabilgo
    replied
    Originally posted by doivaythoiem
    try and feedback
    still no sound
  • doivaythoiem
    replied
    Originally posted by nabilgo
    this bios with no sound and laptop isnt work good i hope ou can guys can makes new bios it have intel i5 8th
    hp elitebook 840 g5
    serial number 5cg8470zjt
    try and feedback
  • shiyab
    replied
    hp elitebook 840 g5
    hi try
  • nabilgo
    replied
    hp elitebook 840 g5
  • jesi
    replied
    thanks bbanana
    main bios flashed , but still the same comes on to no display
    all voltages ok , can you advise anything , maybe i missed something
    thankyou
  • bbanana
    replied
    Originally posted by jesi
    hp elitebook 840 g5
    S/N 5CG9314BT2
    prodID 7JQ98UC#ABA
    computro-6050a2945601
    laptop comes on no display no backlight , few secaonds later cpu fan comes on
    attatched backup of main bios and ec bios
    any help will be appriciated
    thankyou​
    Flash main bios only. ME Cleaned and Bios Region replaced
  • jesi
    replied
    hp elitebook 840 g5
    S/N 5CG9314BT2
    prodID 7JQ98UC#ABA
    thankyou​
  • Karol Wu
    replied
    I need new bios
    I broke my W25Q256JV bios (phisically) from HP EliteBook 840 G5 6050a2945601-mb-a01
    May I ask for BIOS for serial number 5CG013DSCM ProdID 2FA66AV please?
    I tried adjust bios bymyself to change Serial Number with HEX but still I have issue CPU fan spins at maximum speed.
    What I should do to let it run? Will you be able to prepare package for me to let it work?
    Is it requires to flash also second 16MB bios as well?
    Thank you​
  • huzo
    replied
    Originally posted by huzo
    I've got a few 840 G5 laptops in the shop, all of them have simmilar problems, here are the dumps from one of them from both chips , I've tried the dump from few posts above, but only get caps lock turned on....
    S/N 5CG8515SSC
    model 840 G5
    Board number 6050A3022501-MB-A01
    peste , can you please look at these dumps?
  • Muditha Folini
    replied
    Originally posted by peste
    post the contents of the bios chip even if it is corrupted..archive with winrar or 7zip and post..
    post full name and model, motherboard model,
    hp elitebook 840 g5
    S/N 5CG922701G
    SYS. BOARD ID 83B2
    M/B L15518-601
  • peste
    replied
    Originally posted by Muditha Folini
    hello everyone, mistakenly i have read the main bios instead EC chip. now my laptop is working but keyboard is not working properly i think because of the main bios corruption. can someone send me the original main bios file for W25Q256JVEQ chip? in this model EC chip is located under the motherboard which is 128MB chip. in 256MB does not include security things like bios passwords and all. bios password i removed successfully from the 128MB chip by searching active on hxd file but after that also keyboard is not working properly and when i use with bios password it worked very well.i tried to reprogram with the backup that i mistakenly read for 256MB but the issue still appears. maybe i have not read it properly. unfortunately here i can not upload the attachments it says i am not allowed to attach bin file extensions. S/N 5CG922701G PROD ID 2FA66AV. i connected external usb keyboard also but issue persisits. please help me with it. thanks
  • peste
    post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • Muditha Folini
    replied
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • Wahaz
    by Wahaz
    10-30-2023, 08:42 PM
  • traxformania
    TONGFANG "GM7TG7P" Bios Password Problem?
    by traxformania
    I tried :
    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
    11-15-2023, 07:32 AM
  • cyborg17b
    HP Elitebook x360 1040 G5 - This BIOS is Not for Production Use
    by cyborg17b
    Hi guys,
    I have acquired a HP Elitebook x360 1040 G5 laptop with the motherboard model BLURR-6050A2999101-MB-AX3(S3).
    The laptop is actually engineering sample, as it displays this message on the boot screen: "Your system is not fully configured. pLease contact HP customer support.
    Warning: This BIOS is Not for Production Use".
    I had purchased a BIOS chip from ebay to replace the BIOS with the error message, but once installed in the motherboard in the WSON8 adapter, I think their technology "SureStart"...
    01-02-2023, 02:16 PM
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
