HP 840 G5
S/N :- 5CG9256DW8
Showing HP END Point Security Error
Plz fix it
NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
read the forum rules..https://www.badcaps.net/forum/troubl...ore-postingLeave a comment:
I need a bios fixed for 840 G5 MB 6050A2945601-MB-A01(A1) THANK YOU IN ADVANCE!Attached FilesLeave a comment:
but this laptop different customer mb model differentLeave a comment:
please help me
i attached laptop casing and mb vedio, please see this vedio
Re: NEED BIOS FOR HP EliteBook 840 G6
SN: 5CG9387SSY
mb MODEL 6050a2945601-mb-a01
SIR HELP ME PLEASE
NO DISPLAY PROBLEM
EC FILE OTHER ENGINNER CHANGE, I DONT KNOW ITS ORGINAL OR NOT
MAIN FILE ORGINAL FILE
I ATTCHED MY FILE
I WRITE MANY MAIN FILE, BUT FAN FULL SPEED & NO DISPLAYLeave a comment:
For those who need a clean BIOS (no passwords, factory defaults, without DMI) for the HP EliteBook 840 G5 (6050A2945601-MB-A01):
Since nobody here could help me, I turned to Wrong Chip on YouTube (link below). Here's my experience for others facing similar issues:- These BIOS files work—I successfully flashed both by CH341A (modded from 5V for 3.3V!) by Neoprogrammer on Windows:
- 32MB chip (W25Q256JVEIQ)
- 16MB chip (W25Q128JVPQ)
- My W25Q256JVEIQ BIOS was corrupted (physical damagel). You can use my files, but they do NOT include DMI data (you have mine attached for serial 5CG013DSCM)
- DMI Solution: Wrong Chip provided my DMI data, which I injected using the method shown in this video:
- HP Manufacturing Program Mode | WHY it Happens & How to LOCK it
https://www.youtube.com/watch?v=ucZ-nn1aEt0
- Boot Failure? Another reason my laptop wouldn't turn on was accidentally removing the 22-ohm resistor. If your motherboard is unresponsive, double-check all resistors!
My DMI if you don't have yours you can try as above YouTube movie after start
Serial Number: "5CG013DSCM" SKU Number: "2FA66AV"
Board CT Number: "PGWHT00WBDH1KY"
Product Name: "HP EliteBook 840 G5"
BuildID: "17WWCSDT601#SABD#DABD"
Feature Byte: "3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPfXhKhkjh.fm"
MAC Address: "10-62-E5-56-A7-0D"
is your caps lock stuck on - you should ask for a solution to this? -
SN: 5CG9387SSY
SIR HELP ME PLEASE
NO DISPLAY PROBLEM
I ATTCHED MY FILE
this bios with no sound and laptop isnt work good i hope ou can guys can makes new bios it have intel i5 8th
hp elitebook 840 g5
serial number 5cg8470zjt
thanks bbanana
main bios flashed , but still the same comes on to no display
all voltages ok , can you advise anything , maybe i missed something
thankyouLeave a comment:
hp elitebook 840 g5
S/N 5CG9314BT2
prodID 7JQ98UC#ABA
computro-6050a2945601
laptop comes on no display no backlight , few secaonds later cpu fan comes on
attatched backup of main bios and ec bios
any help will be appriciated
thankyouAttached FilesLeave a comment:
I need new bios
I broke my W25Q256JV bios (phisically) from HP EliteBook 840 G5 6050a2945601-mb-a01
May I ask for BIOS for serial number 5CG013DSCM ProdID 2FA66AV please?
I tried adjust bios bymyself to change Serial Number with HEX but still I have issue CPU fan spins at maximum speed.
Is it requires to flash also second 16MB bios as well?
Thank youLeave a comment:
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by lap-top123HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
Hp Elitebook 850 G8
ProdID 52W98EC#ABD
SN# 5CG1458XQ7
Mac-address #1: 84:14:4D:2C:4B:5B
UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
Mainboard : 6050A3216701-MB-A01(A1)-
- Loading...
