NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
  • danito
    • Jun 2016
    • 968
    #441
    Originally posted by Bak Ron
    Can someone help?
    try
    • maniche
      • Jun 2020
      • 37
      • Kabylie
      #442
      Originally posted by Blaze Tech
      Try
      thank you very much, unfortunately it didn't work, I think this laptop has another problem, thanks again​
      • huzo
        • Sep 2014
        • 178
        • CROATIA
        #443
        I've got a few 840 G5 laptops in the shop, all of them have simmilar problems, here are the dumps from one of them from both chips , I've tried the dump from few posts above, but only get caps lock turned on....
        S/N 5CG8515SSC
        model 840 G5
        Board number 6050A3022501-MB-A01
        • Karol Wu
          • May 2025
          • 5
          • Poland
          #444
          Dear Blaze Tech and others
          I broke my W25Q256JV bios (phisically) from HP EliteBook 840 G5 6050a2945601-mb-a01
          May I ask for BIOS for serial number 5CG013DSCM ProdID 2FA66AV please?
          I tried adjust bios bymyself to change Serial Number with HEX but still I have issue CPU fan spins at maximum speed.
          • Muditha Folini
            • May 2025
            • Schweiz
            #445
            hello everyone, mistakenly i have read the main bios instead EC chip. now my laptop is working but keyboard is not working properly i think because of the main bios corruption. can someone send me the original main bios file for W25Q256JVEQ chip? in this model EC chip is located under the motherboard which is 128MB chip. in 256MB does not include security things like bios passwords and all. bios password i removed successfully from the 128MB chip by searching active on hxd file but after that also keyboard is not working properly and when i use with bios password it worked very well.i tried to reprogram with the backup that i mistakenly read for 256MB but the issue still appears. maybe i have not read it properly. unfortunately here i can not upload the attachments it says i am not allowed to attach bin file extensions. S/N 5CG922701G PROD ID 2FA66AV. i connected external usb keyboard also but issue persisits. please help me with it. thanks
            • peste
              peste commented
              Editing a comment
              post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          • peste
            • 12868
            • ROMANIA
            #446
            post the contents of the bios chip even if it is corrupted..archive with winrar or 7zip and post..
            post full name and model, motherboard model,
            • Muditha Folini
              • May 2025
              • Schweiz
              #447
              hp elitebook 840 g5
              S/N 5CG922701G
              SYS. BOARD ID 83B2
              M/B L15518-601
              • huzo
                • Sep 2014
                • 178
                • CROATIA
                #448
                S/N 5CG8515SSC
                model 840 G5
                peste , can you please look at these dumps?
                • Karol Wu
                  • May 2025
                  • 5
                  • Poland
                  #449
                  I need new bios
                  What I should do to let it run? Will you be able to prepare package for me to let it work?
                  Is it requires to flash also second 16MB bios as well?
                  Thank you​
                  • jesi
                    • Jul 2013
                    • 67
                    • uk
                    #450
                    hp elitebook 840 g5
                    S/N 5CG9314BT2
                    prodID 7JQ98UC#ABA
                    computro-6050a2945601
                    laptop comes on no display no backlight , few secaonds later cpu fan comes on
                    attatched backup of main bios and ec bios
                    any help will be appriciated
                    thankyou​
                    • bbanana
                      Father Land
                      • Oct 2021
                      • 164
                      • Vietnam
                      #451
                      Originally posted by jesi
                      hp elitebook 840 g5
                      S/N 5CG9314BT2
                      prodID 7JQ98UC#ABA
                      thankyou​
                      Flash main bios only. ME Cleaned and Bios Region replaced
                      • jesi
                        • Jul 2013
                        • 67
                        • uk
                        #452
                        thanks bbanana
                        main bios flashed , but still the same comes on to no display
                        all voltages ok , can you advise anything , maybe i missed something
                        thankyou
                        • nabilgo
                          • May 2016
                          • 303
                          • L.A
                          #453
                          this bios with no sound and laptop isnt work good i hope ou can guys can makes new bios it have intel i5 8th
                          hp elitebook 840 g5
                          serial number 5cg8470zjt
                          • shiyab
                            • Sep 2023
                            • 1495
                            • india
                            #454
                            hp elitebook 840 g5
                            hi try
                            • doivaythoiem
                              • Jun 2024
                              • 104
                              • Việt Nam
                              #455
                              hp elitebook 840 g5
                              try and feedback
                              • nabilgo
                                • May 2016
                                • 303
                                • L.A
                                #456
                                Originally posted by doivaythoiem
                                try and feedback
                                still no sound
                                • Karol Wu
                                  • May 2025
                                  • 5
                                  • Poland
                                  #457
                                  For those who need a clean BIOS (no passwords, factory defaults, without DMI) for the HP EliteBook 840 G5 (6050A2945601-MB-A01):
                                  Since nobody here could help me, I turned to Wrong Chip on YouTube (link below). Here's my experience for others facing similar issues:
                                  1. These BIOS files work—I successfully flashed both by CH341A (modded from 5V for 3.3V!) by Neoprogrammer on Windows:
                                    • 32MB chip (W25Q256JVEIQ)
                                    • 16MB chip (W25Q128JVPQ)
                                  2. My W25Q256JVEIQ BIOS was corrupted (physical damagel). You can use my files, but they do NOT include DMI data (you have mine attached for serial 5CG013DSCM​)
                                  3. DMI Solution: Wrong Chip provided my DMI data, which I injected using the method shown in this video:
                                  4. Boot Failure? Another reason my laptop wouldn't turn on was accidentally removing the 22-ohm resistor. If your motherboard is unresponsive, double-check all resistors!
                                  • faisalhabib
                                    • Apr 2017
                                    • 25
                                    • Bangladesh
                                    #458
                                    Re: NEED BIOS FOR HP EliteBook 840 G6
                                    SN: 5CG9387SSY
                                    mb MODEL 6050a2945601-mb-a01
                                    SIR HELP ME PLEASE
                                    NO DISPLAY PROBLEM
                                    EC FILE OTHER ENGINNER CHANGE, I DONT KNOW ITS ORGINAL OR NOT
                                    MAIN FILE ORGINAL FILE
                                    I ATTCHED MY FILE
                                    I WRITE MANY MAIN FILE, BUT FAN FULL SPEED & NO DISPLAY
                                      SMDFlea commented
                                      Editing a comment
                                      is your caps lock stuck on - you should ask for a solution to this?
                                  • Karol Wu
                                    • May 2025
                                    • 5
                                    • Poland
                                    #459
                                    2. My W25Q256JVEIQ BIOS was corrupted (physical damagel). You can use my files, but they do NOT include DMI data (you have mine attached for serial 5CG013DSCM)
                                    Click image for larger version  Name:	HP840G5.jpg Views:	52 Size:	156.9 KB ID:	3647994
                                    Reupload 2x missed packages to flash as new BIOS
                                    My DMI if you don't have yours you can try as above YouTube movie after start
                                    Serial Number: "5CG013DSCM" SKU Number: "2FA66AV"
                                    Board CT Number: "PGWHT00WBDH1KY"
                                    Product Name: "HP EliteBook 840 G5"
                                    BuildID: "17WWCSDT601#SABD#DABD"
                                    Feature Byte: "3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPfXhKhkjh.fm"
                                    MAC Address: "10-62-E5-56-A7-0D"
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11809
                                      #460
                                      SN: 5CG9387SSY
                                      SIR HELP ME PLEASE
                                      NO DISPLAY PROBLEM
                                      I ATTCHED MY FILE
                                      You don't have a video because these files are from HP EliteBook 840 G5
                                      • STKR123
                                        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                        by STKR123
                                        Greetings badcaps community,
                                        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                        I learned that desoldering...
                                        10-29-2024, 06:03 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • Guest
                                        Elitebook 850 G5 BIOS bricked
                                        by Guest
                                        I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                        I assume the BIOS update failed, so I searched for the BIOS chip.
                                        I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                        However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                        Can the corrupted...
                                        03-24-2025, 01:21 AM
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
