doesnt work rc unlocker tryed and have black screen
NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
XXX
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
I also have a HP 840 G5 which powers on, Caps Lock blinks 5 times, then fan goes into fast mode
Everything looks OK, all voltages are there except VCore (the regulator responsible for VCore doesn't get configured via SVID).
S/N: 5CG8322JTC
Thanks!
Attached FilesComment
Thanks! I actually learned to rebuild the BIOS image by myself in the meantime. There was a problem with ME region. Bad checksum and structure was even detected by MEAnalyzer.
The notebook works fine with my rebuilt image. Thanks anyway!
On first start it actually behaved the same (caps lock flashes, fast fan) but after that the fan stopped and the system started to boot. So if anyone is facing the same issue and trying the repaired bios, be patient on first start after flashing new image.Comment
I'm having the same problems as many others where the laptop fails to boot. Is it possible to clean the bios?
Also, ME Analyzer reports Error: Detected CSE Extension 0x03 with wrong Partition Hash at FTPR > FTPR.man! on this file.
Thanks .S/N:5CG9256VP8Attached FilesComment
I did the same process (replacing the ME region with clean one) as I did in my case. However, I could not find the exact same version of the ME that you have in your BIOS image. So I used the same version that worked for mine.
Your version: 11.8.94.4494
I used: 11.8.95.4551
So don't be mad if the laptop self-destructs after booting with my rebuilt image
The ME Analyzer error is fixed with my rebuilt image. My error was exactly the same...
Hello Masters of Badcaps,
Need some help in fixing this bios that comes from a failed update. Now the laptop only flashes the capslock key and the power key.
HP Elitebook 840 G5 bios dump attached.
Many thanks!
RayComment
Hi SMDFlea, very sorry for having omitted this. SN# is 5CG9218GN1 - Thank you!Comment
Both bios from failed update on a HP Elitebook 840 G5 SN# is 5CG9218GN1. When it failed, after only the caps lock key led comes on white and no response to power button. Thank you for any help!
Hp elite book 840-G5
Board part no : 6050A2945601-mb-A01
S/n : 5CG91339GN
Prod I'd : 3RF11UT#ABA
Problem : endpoint security controller error showing
I'll attached the both file main and ec file can clear this errorAttached FilesComment
CCCAttached Files
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
Channel: BIOS Requests ONLY!
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
