lenovo miix 520-12IKB
  • kdesouky
    • Dec 2021
    • 6
    Re: lenovo miix 520-12IKB
    I managed to upload the file to another person who helped me to retrieve the admin password.
    Thank you for all of your help.
    • MrMike25
      • Mar 2022
      • 6
      Re: lenovo miix 520-12IKB BIOS Password
      I have 10 Lenovo MIIX 520-12IKB and the BIOS password I have isn't working. All the machines did and should have the same BIOS password. I have uploaded the bin file I saved from one of the machines and I hope if that password can be found it will work on the other ones. Any help would be greatly appreciated. If more information is needed, please let me know. Thanks!
      • AAAC
        • Jan 2020
        • 458
        • Mexico
        @MrMike25, good luck!
        password = OABPWD4W10
        O - OSCAR ( UPPERCASE )
        A - ALFA ( UPPERCASE )
        B - BRAVO ( UPPERCASE )
        P - PAPA ( UPPERCASE )
        W - WHISKY ( UPPERCASE )
        D - DELTA ( UPPERCASE )
        4 - 4 ( digit )
        1 - 1 ( digit )
        0 - zero ( digit )
        • MrMike25
          • Mar 2022
          • 6
          AAAC, you're awesome! Thank you so much!! It worked on 7 of them but 3 it did not. I hope you can help on the last three. They should be the same as the other ones but weren't so who knows. I uploaded the bin files hoping you might be able to get the password for the last three. Thank you again for all your help!!
            • 20781
            You can unlock them yourself using a hex editor. The offset is in the picture,the highlighted area is a keyboard scancode. 30 = B ,and so on.
            https://www.win.tue.nl/~aeb/linux/kbd/scancodes-1.html
            https://github.com/tianocore/edk2/bl...KeyBoard.c#L36
            • MrMike25
              • Mar 2022
              • 6
              SMDFlea, Thank you for sending the information. This is great information and I will need it in the future for sure.
              I think I'm confused because this Lenovo doesn't let me use upper case or special characters. The password which was provided earlier only worked when I used lower case because upper case doesn't show anything is being typed. Does 30 = B as in I need to look at the upper case line? If that is the case then the special characters will not work.
              So, from the scan code and the hex editor I get BPWD410M10H (looking at the Keyboard scan code under key then the left side example 02 = 1 not !) but it doesn't work. Also, the 6D gets me confused because it's not in the scan code area so I looked over under normal and saw it says M.
              BTW, yes all the last three have the same 30 19 11 20 05 02 0B 6D 02 0B code under 00201000.
              • MrMike25
                • Mar 2022
                • 6
                SMDFlea, I finally got it! I needed to stop at the 6d so the password was BPWD410, just the first 7 and not the entire line. Anyway, thank you for all your help!
                • croccomp
                  • 20
                  That was very useful, is there anywhere on the site that shows where the offset is for other makes/models?
                  Cheers
                  • onizzbox
                    Banned
                    • Nov 2018
                    • 604
                    • Brazil
                    #29
                    Cheers
                    @croccomp
                    The script in scan mode finds the first instance of the encoder, that's the reason.
                    • croccomp
                      • 20
                      Hi, bit of a noob is there a thread that shows how to do that?
                      • qb92353
                        • Jun 2022
                        #31
                        I read trough this whole thread and i am confused as how to read the BIOS chip so i can extract the password from it, I juat bought a new motherboard for my MIIX 520 20M3 and despite that the bios password is still here.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11690
                          #32
                          That device is called a Programmer. Do a google search on how to use it and there are many brands.
                          • peste
                            • 12729
                            • ROMANIA
                            #33
                            to read the bios chip you will need an SPI programmer ... and in the contents of the bios chip the password is deleted.
                            https://www.youtube.com/watch?v=DWWigscuQDY
                            • qb92353
                              • Jun 2022
                              #34
                              Where do I find the BIOS chip on the motherboard? I've been searching for a while but i cannot seem to find it and i thought about getting one of those programmers but now I will since i need it for this.
                              • peste
                                • 12729
                                • ROMANIA
                                #35
                                we don't know all the boards either ... post clear pictures with the motherboard on both sides ...
                                • qb92353
                                  • Jun 2022
                                  #36
                                  I have two motherboards they are identical, this one is a broken one I use for testing aince its easier than opening my laptop and taking it apart every time
                                  • peste
                                    • 12729
                                    • ROMANIA
                                    #37
                                    u3002 .. to the right of the processor in the first photo
                                    • qb92353
                                      • Jun 2022
                                      #38
                                      Found it! Mersii now i can get the BIOS programmer so i can read whats on it.
                                      • peste
                                        • 12729
                                        • ROMANIA
                                        #39
                                        at post # 34 then sent a video ... watch it and after the decision to buy a programmer ..
                                        • Dawid1187
                                          • Jun 2022
                                          • Polska
                                          #40
                                          Hello
                                          I have a problem with the password for the Miix 520. I am asking for help with reading the password. Thank you in advance for your help and best regards .
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • grimacelord
                                            by grimacelord
                                            Hello there.
                                            History:
                                            03-15-2023, 03:29 PM
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
                                          • mximiliandz
                                            help bios lenovo ideapad s145-14iil type 81w6
                                            by mximiliandz
                                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                            06-20-2025, 06:50 AM
                                          • 1g0r
                                            Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                            by 1g0r
                                            First, the data in brief:
                                            Manufacturer: Lenovo
                                            Model: ThinkPad L15 G3 21C3-0016GE
                                            motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                            IC Bios 1: MX77L25650F
                                            IC Bios 2​: MX25L25673G
                                            EC Chip: NPCX997KAABX
                                            So far I've been a silent reader, but now I need your help
                                            I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                            I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                            The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                            01-18-2025, 02:39 AM
