help unlock passbios unowhy Y13G010S4EI
  • ladharimohamed2
    • Jul 2021
    • 40
    • tunisia
    #81
    unowho Y13G011S4EI Bios Problem
    Hi, i have a laptop that has a bios password so i searched for bios bin files.
    when i tried some bin files the screen went black and the problem is that i didnt backup my original image. i tried all that i found here and others elsewhere with no luck. can anyone please provide me an image identical to mine even with a password is no problem. thanks
    Laptop Model: UNOWHY Y13G011S4EI
    Motherboard Model: EM_IG116_200B_ENE_F_V1.0
    Production date : Juin 2021
    • volinakis
      • Jan 2021
      • 2790
      • N/A
      #82
      Re: unowho Y13G011S4EI Bios Problem
      bad luck ...
      • volinakis
        • Jan 2021
        • 2790
        • N/A
        #83
        Try this and give feedback
        • ladharimohamed2
          • Jul 2021
          • 40
          • tunisia
          #84
          laptop wont turn on with that file. (no light, no cpu heat)
          with the others laptop turns on i see green light and feel cpu heat but the screen stays black.
          • volinakis
            • Jan 2021
            • 2790
            • N/A
            #85
            indicate a bios dump you used, I will try to clean TXE.
            • ladharimohamed2
              • Jul 2021
              • 40
              • tunisia
              #86
              Hi volinakis, those are three files that laptop turn on but without picture on screen that has the same name board name. pick any of them
              Thank a lot <3
              • volinakis
                • Jan 2021
                • 2790
                • N/A
                #87
                Thank a lot <3
                ok, try this one. I cleaned TXE Region from 1st bios dump.
                • ladharimohamed2
                  • Jul 2021
                  • 40
                  • tunisia
                  #88
                  Thanks a lot. muchas gracias amigo <3 <3
                  • volinakis
                    • Jan 2021
                    • 2790
                    • N/A
                    #89
                    good to know it's working, for others wanting to use this bios is for Laptop Model: UNOWHY Y13G011S4EI
                    DMI data starting at 20FF0
                    • farouk_1994
                      • Mar 2021
                      • 393
                      • algeria
                      #90
                      Re: help unlock passbios unowhy Y13G010S4EI
                      PLEASE NEED UNLOCK THIS BIOS unowhy Y13G010S4EI 2021
                      • sarroura
                        • Feb 2023
                        • 10
                        • France
                        #91
                        I have a stupid question, but can someone explain to me how to install the bios bin file for my unowhy Y13. is it done with software, and if so how to bypass the administrator authorization to install it, because it is password protected or do you have to go through an external programmer. THANKS
                        I need also to know how to extract my bios bin file. Thanks
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #92
                          Yes, you have "to go through an external programmer", also you have to read the sticky threads first before asking more "stupid questions". All sticky threads.
                          Become a Badcaps supporter
                          Thanks to all supporters.
                          • sarroura
                            • Feb 2023
                            • 10
                            • France
                            #93
                            Unowhy Y13 . I have to unplug the battery connector before flashing the bios. But I can't remove this connector and I pulled hard but it doesn't disconnect. I'm afraid to break it. Is there a special way to remove it? THANKS
                            • sarroura
                              • Feb 2023
                              • 10
                              • France
                              #94
                              that's ok . Thank you for your help
                              • Phil94
                                • Jan 2023
                                • 7
                                • France
                                #95
                                Originally posted by corona100
                                wrong chip this dump only 1 mb the original bios dump have 8mb
                                Dear corona100
                                I just finished extracting the file of the bios.bin , it is at 8195ko, here it is compress to 5116ko ,
                                Let me know if you can help me so delete or change this password ,
                                Tell me in this case what I should put in the case password
                                Let me know what you can do by thanking you in advance
                                • nonomanita
                                  • Feb 2018
                                  • 29
                                  • algeria
                                  #96
                                  please unlock pass bios!
                                  • volinakis
                                    • Jan 2021
                                    • 2790
                                    • N/A
                                    #97
                                    Try
                                    • nonomanita
                                      • Feb 2018
                                      • 29
                                      • algeria
                                      #98
                                      Try
                                      Thank you very much !
                                      • Phil94
                                        • Jan 2023
                                        • 7
                                        • France
                                        #99
                                        [QUOTE=Phil94;1214969]
                                        Hi ,
                                        Could you help me to unlock password of bios for unowhy_Y13 model : Y13G011S4EI ?
                                        motherboard is EM_IG116_200B_ENE_F_V1.0
                                        File.bin in attchment
                                        Which password could be associated ?
                                        • rachidell
                                          • Aug 2016
                                          • 137
                                          • algeria
                                          #100
                                          can you help me for unowhy Y13G010S4EI no display
                                          thanks
