help bios unlock Unowhy Y13G011S4EI
Please help me unlock the bios on the bios there is a passwordTags: None -
Re: help bios unlock Unowhy Y13G011S4EI
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donate -
this my locked file pleas helpAttached Filesif you find these attachements useful please consider making a small donation to the site
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
[QUOTE=hunter-s;n3254490]help bios unlock Unowhy Y13G011S4EI
[QUOTE=hunter-s;n3254652]try this and replayAttached Filesif you find these attachements useful please consider making a small donation to the site
I have Y13G011S4EI bios passe word
N: IFP130073373
CM: EM IG116 200B ENE F V 1.0Attached Filesif you find these attachements useful please consider making a small donation to the site
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
IG116-200B PASSWORD BIOS please unipass sn ifp122009367Attached Filesif you find these attachements useful please consider making a small donation to the site
UnlockedAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by piratiHello everyone,
- Loading...
