help unlock passbios unowhy Y13G010S4EI
  • CHERIF
    • Jan 2021
    • 16
    • Mali
    #261
    [QUOTE=dihcar84
    no power with this
    you have to press power for 4 second in first after soldering the chip
    • douba
      • Jan 2020
      • 15
      • Algeria
      #262
      Hi
      please unlock pass bios of UNOWHY Y13G113S4EI with number IFP323107031
      (I Tried with the method of SMDFlea​ and i unlocked one y13G010S4E1 successfully - thanks a lot to you ) but with this bios i have a Black screen
      Please help me
      • douba
        • Jan 2020
        • 15
        • Algeria
        #263
        Hi
        i tried this bios "thanks to volinakis​" and its ok for me
        please can you show me how you did this ??? it was very hard for me
        • hoaca388
          Badcaps
          • Jan 2022
          • 12354
          #264
          Originally posted by douba
          Hi
          i tried this bios "thanks to volinakis" and its ok for me
          Do you know what your post is missing, it's the serial number.
          You MUST:
          • Read BIOS guides, methods, resources and tools
          • Try the method at BIOS guides, methods, resources and tools before requesting help
          • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
          • Use search function in case someone already answered your request
          • Post under a related thread if it exists
          • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
          • Name your thread with make, full model numbers and request
          • Provide a BIOS/EC dump if possible
          • Attach files directly to your post instead of linking to external websites
          • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
          • hedilawi
            • Feb 2017
            • 8
            • monastir
            #265
            please unlock
            2020 model
            EM_IG116_366B_V2.0
            i try many bios but all no display
            also i try to unlock but pass still
            thanx
              • 22001
              Originally posted by hedilawi
              please unlock
              2020 model
              EM_IG116_366B_V2.0
              thanx
              Read https://www.badcaps.net/forum/troubl...before-posting post the serial number IFP????????
              • hedilawi
                • Feb 2017
                • 8
                • monastir
                #267
                IFP029038712 SORRY BRO
                • volinakis
                  • Jan 2021
                  • 2874
                  • N/A
                  #268
                  try
                  • volinakis
                    • Jan 2021
                    • 2874
                    • N/A
                    #269
                    I will try to explain how I remove passwords in Unowhy:
                    1. Open bios backup file with hex editor.
                    2. Search for text "AMITSE".
                    3. Copy hex values found under "AMITSESetup" entry into a text editor - sometimes there are 2 strings of 32bytes each - see photos
                    4. Fill with "00" hex strings of 32bytes found under "AMITSESetup" entry
                    5. Search for hex strings of 32bytes copied in text editor -you'll find them in many places, sometimes in 5-6 places. Fill them with "00"
                    6. Search for text "NVAR[" or hex "4E5641525B" - sometimes there are 3rd or 4th password in that entry. They have also 32bytes. Fill them with "00"
                    7. Photos are from bios backup of post 265 with 4 passwords. Usually there are only 2 passwords of 32bytes, this is an unusual case.
                    Click image for larger version  Name:	Screen Shot 2025-04-10 at 18.10.19.png Views:	0 Size:	99.1 KB ID:	3612184
                    Click image for larger version  Name:	Screen Shot 2025-04-10 at 18.10.38.png Views:	0 Size:	102.0 KB ID:	3612185
                    Click image for larger version  Name:	Screen Shot 2025-04-10 at 18.17.56.png Views:	0 Size:	114.9 KB ID:	3612186
                    • cr4ck3r
                      • Aug 2013
                      • 8
                      #270
                      Hello!
                      Can anyone please unlock my bios dump? I've tried the above tutorial with no success.
                      UNOWHY Y13G010S4EI
                      S/N: IFP050028407
                      Motherboard: EM_IG116_366B_ENE_V2.0
                      Thank you!
                      • peste
                        • 13661
                        • ROMANIA
                        #271
                        Originally posted by cr4ck3r
                        Hello!
                        UNOWHY Y13G010S4EI
                        S/N: IFP050028407
                        Thank you!
                        try..
                        • cr4ck3r
                          • Aug 2013
                          • 8
                          #272
                          Originally posted by peste
                          try..
                          Doesn't work.
                          I've succeeded with AMITSetup decryptor and unlocker.
                          Thank you!
                          Multumesc!
                          • Amentechshop
                            • Apr 2023
                            • 9
                            • Tunisia
                            #273
                            hey guys laptop y13g011s4ei with bios password
                            i found bios clear somewhere it worked but pc no longer have sound i figured it may be something about bios can someone fix it for me and thanks in advance.
                            • peste
                              • 13661
                              • ROMANIA
                              #274
                              post S/N, full name and model, motherboard model,etc.
                              • Amentechshop
                                • Apr 2023
                                • 9
                                • Tunisia
                                #275
                                laptop ile-de-france , Unowhy y13g011s4ei
                                prodect 2021
                                MB number EM_IG116_200B_ENE_F_V1
                                  • 22001
                                  prodect 2021
                                  Post the serial number....... IFP************
                                  • Amentechshop
                                    • Apr 2023
                                    • 9
                                    • Tunisia
                                    #277
                                    ok my bad : IFP128021258
                                    • Amentechshop
                                      • Apr 2023
                                      • 9
                                      • Tunisia
                                      #278
                                      hey sorry to bother you i cleared it by following "Find the keyword " amitsesetup" and select the block like the picture attached and fill it with the characters " 00 00 ...".
                                      and i have sound problem solved thanks
                                      • Jacques makula
                                        Jacko
                                        • Apr 2025
                                        • Congo-Kinshasa
                                        #279
                                        Salut! J'ai téléchargé un de fichiers joints des amis que vous avez partagé concernant la reinitialisation de la Bios pour Y13G010S4EI dont le n° est IFP048013239 de 2020.
                                        Comment puis-je procéder avec c fichier .Bin?
                                        La suite du procedure Svp!
                                        Hi! I downloaded one of the attachments from your friends that you shared regarding resetting the BIOS for Y13G010S4EI, whose file number is IFP048013239 from 2020.
                                        How do I proceed with this .Bin file?
                                        The rest of the procedure, please!​
                                        in English please..
                                        • Jacques makula
                                          Jacko
                                          • Apr 2025
                                          • Congo-Kinshasa
                                          #280
                                          Hi! I downloaded one of the attachments from your friends that you shared regarding resetting the BIOS for the Y13G010S4EI, file number IFP048013239 from 2020.
                                          Please I need to unlock the BIOS!
