Hp 15-ra000nk (15-ra0xx) clean me.
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Hello my friends.This lab comes no power , someone before me mess with the bios , try to clean me but find this error : found unidentifiable intel engine firmware what mean : This usually indicates that something went wrong during dumping or similar ( plutomaniac).
    So can someone give help , thank you
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Hp 15 clean me.
    Is my dmi info adress is this : 1FC080-1FD08F !
      • 22279
      Re: Hp 15 clean me.
      Do you have the full laptop model number
      • lapfix
        • Mar 2020
        • 2764
        • my workshop
        Re: Hp 15 clean me.
        yes , and i successfully download the new bios ver F.67 Rev.A.
        the lap work , only at external ; i have a doubt about a screen too ( broken)
        and the habituel message : manufacturing programing mode is unlock mode.
        that's why i m asking about the DMI.
          • 22279
          Re: Hp 15-ra000nk (15-ra0xx) clean me.
          bios + dmi .
          • lapfix
            • Mar 2020
            • 2764
            • my workshop
            Tahnk you SMDflea for your precious helps
            Your bios is perfect with all my DMI present , only lap ask me at start : manufacturing programming mode is in unlock mode ...and i have a tool to fix it...thank you again
            • anton brunner
              Having a hard time dumping BIOS - Lenovo Ideapad Duet 3 (11IAN8)
              by anton brunner
              I'm having a hard time dumping the BIOS of a Lenovo Ideapad Duet 3 (11IAN8). The chip is a Winbond W25R256JVEN, directly soldered to the board in a WSON8 package.
              Since there are lots of tiny components near the chip, I was hesitant to desolder it using hot air. Instead, I soldered thin wires directly to the chip's pads and connected them to a CH341A programmer (photos attached).
              The chip is detected correctly in both NeoProgrammer and ASProgrammer, but I'm unable to get a consistent dump. I've tried over 15 times — shortened the wires to...
              05-15-2025, 01:01 AM
            • bk304
              Dumping BIOS contents
              by bk304
              Hello All,
              This is my first post. Please let me know if I am posting in the wrong place.
              Is there a way of dumping BIOS contents without hooking up to the chip? I have seen an older program that does this but it would not run on Windows 11. I don't know if this is something that only works on legacy bios or can also work in Windows UEFI....
              01-27-2025, 12:37 PM
            • Sathsul
              Dell Latitude 5431 issues with dumping bios
              by Sathsul
              So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
              The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
              However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
              10-28-2025, 07:49 AM
            • Daniel Larsson
              Help me verify my NAND dump (attached) from LG SK10Y soundbar stuck in PLEASE WAIT - is it missing critical data?
              by Daniel Larsson
              I’m trying to bring a LG SK10Y soundbar back to life. Currently it is stuck in the “PLEASE WAIT” loop.
              My conclusion so far is that something fails to boot fully, but it does start via eARC and can play perfectly good sound until watchdog shuts it down.
              After dumping NAND with a T48 programmer, extracting with binwalk and exploring with Ghidra I think:
              • Kernel B is present, but no Kernel A. Is that normal?
              • SquashFS A/B are present
              • Bootloader is present
              • UBI region is completely empty (only volume 0 / layout volume exists)
              • No system.cfg,
              11-13-2025, 03:19 PM
            • stallonh
              ThinkPad P14s Gen5 AMD bios mod
              by stallonh
              I have a ThinkPad P14s Gen5 AMD and want to use an SSD in the WWAN interface. During the process, I used a CH341A to dump the BIOS file, but I couldn't open the .bin file with UEFITool. Can anyone tell me what might be causing this? I've uploaded some images and the .bin file. Some users on other forums mentioned needing a 1.8V adapter card—will using a 1.8V adapter prevent this error when dumping the file? ...
              10-12-2025, 11:47 PM
