ThinkPad P14s Gen5 AMD bios mod
  • stallonh
    • Oct 2025
    • 7
    • China
    I have a ThinkPad P14s Gen5 AMD and want to use an SSD in the WWAN interface. During the process, I used a CH341A to dump the BIOS file, but I couldn't open the .bin file with UEFITool. Can anyone tell me what might be causing this? I've uploaded some images and the .bin file. Some users on other forums mentioned needing a 1.8V adapter card—will using a 1.8V adapter prevent this error when dumping the file?
  • stallonh
    • Oct 2025
    • 7
    • China
    Thank you, peste, for your help.
    Supplementary Information:
    · Laptop Model: ThinkPad P14s Gen5 AMD (21ME)
    · Serial Number: PF5BD8VA
    · Motherboard Model: 21MECTO1WW
    · BIOS Type: Lenovo UEFI
    · BIOS Chip: 25LB128ESIG
    · BIOS Version: R2LET35W (1.16) - AMD AGESA PhoenixPI-FP8-FP7 1.2.0.0
    · SMBIOS Version: 3.3
    · CPU Microcode: 0xA70520A
      SMDFlea commented
      Editing a comment
      Posts moved to a new thread as it`s an AMD model
  • stallonh
    • Oct 2025
    • 7
    • China
    Updated Information:
    · Serial Number: PF5BD8VA (The serial number is correct. The laptop was purchased through an official refurbished channel.)
    · Motherboard Model: NM-G031
      • 21919
      The chip is 1.8V so yes, use an adapter. There might be another chip on the board 256Mb , the 128Mb chip might be the recovery bios not sure.
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • maanee11
        Help to get Lenovo BIOS bin file for Thinkpad T560
        by maanee11
        Hello Everyone,
        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
        05-15-2022, 11:59 AM
      • akwky
        by akwky
        Hi!
        04-14-2025, 01:56 PM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
