Lenovo IdeaPad 3 15ADA05
  • cfhong2000
    • Nov 2022
    Re: Lenovo IdeaPad 3 15ADA05
    Originally posted by peste
    bios extracted from Lenovo site update..
    DMI 1000-2FFF
    Thanks a lot. This resolved my laptop
    IdeaPad 3-17ADA05.
    • coelectron
      • Mar 2014
      • 61
      • Argentina
      #42
      Originally posted by tracker1
      Working bios Lenovo IdeaPad 3 15ADA05
      GS450/GS550&GS750 NM-C821 Rev 1.0
      working excelent
      Note: this bios voltage supply is 1.8v
      • biniu1978
        • May 2022
        • 25
        • United Kingdom
        #43
        hi. where is located serial and windows key in bios file. try find location but not luck. can you help me please. Thank You
        my file added.
        Lenovo IdeaPad 3 14ADA05
        NM-C821
        REV : 1.0
        • hardware1
          • Sep 2021
          • 2948
          • N/A
          #44
          my file added.
          NM-C821
          REV : 1.0
          Your device information is Encrypted, if you want to move it to a new file, you can just copy the block from offset (0h) to (3000h).
          There's no OEM Windows Key in your dump file.
          all donations are welcome,
          • fire1234
            • Dec 2017
            • 77
            • Poland
            #45
            The windows key is in the bios (of course it is encoded) TNMBD-82VXC-XXXXX-WC97G-XXXXX, and the serial number is PF1SM4RC
            • hardware1
              • Sep 2021
              • 2948
              • N/A
              #46
              That's interesting, because I can't access to them with normal methods.
              • johnny257
                • 23
                #47
                wow thx. a client just pop in with the same mainboard. will update later
                • sasser
                  • Dec 2012
                  • 365
                  • Malaysia
                  #48
                  hye i try all bios here. my board NM-C821 14ADA . laptop cant boot keep flash led on switch button.
                  • peste
                    • Dec 2016
                    • 13581
                    • ROMANIA
                    #49
                    try the bios from post #29..it is for the following laptops..V14-ADA, V15-ADA, ideapad 3-14ADA05, ideapad 3-15ADA05, ideapad 3-17ADA05..if it doesn't work you have another problem..don't forget to make a copy of the original bios of the laptop..
                    • admv
                      • Jan 2023
                      • Bulgaria
                      #50
                      Hi, I have successfully flashed the bios with the one provided earlier in the thread and the laptop turned on. However, in BIOS the MTM, Lenovo SN, UUID Number and the other fields regarding the laptop on the main screen are empty.
                      IdeaPad 3 15ada05
                      SN PF272AZ5
                      MTM 81W10097BM
                      Factory ID JVHFC1
                      MO PF9XB0418028
                      • hardware1
                        • Sep 2021
                        • 2948
                        • N/A
                        #51
                        IdeaPad 3 15ada05
                        SN PF272AZ5
                        MTM 81W10097BM
                        Factory ID JVHFC1
                        MO PF9XB0418028
                        Here's your New Bios, it's a Virgin Bios from Lenovo with your DMI.
                        • admv
                          • Jan 2023
                          • Bulgaria
                          #52
                          Thank you. It is working as expected.
                          • hardware1
                            • Sep 2021
                            • 2948
                            • N/A
                            #53
                            You're Welcome.
                            • rexo63
                              • Feb 2017
                              • 11
                              • Italia
                              #54
                              Hi guys, i've a problem with one 15ADA05, sometimes won't boot the OS.
                              If the problem is the bios, the serial number is: PF294VE5
                              Thanks for all, guys
                              • peste
                                • Dec 2016
                                • 13581
                                • ROMANIA
                                #55
                                did you read post#49???
                                • ramrk
                                  • Feb 2019
                                  • 155
                                  • India
                                  #56
                                  thank you working
                                  • okimo
                                    • Dec 2012
                                    • 11
                                    • Srbija
                                    #57
                                    Thanks.Excellent!
                                    • joezik6
                                      • Jun 2018
                                      • panama
                                      #58
                                      I am working on a 17ADA05 NM-C821, I tried putting a bios file with integrated ram disabled, and didn't work, I tried to put my original bios again in the chip but it's not working either, any ideas, this is my original bios file.
                                      • jgarric
                                        • Mar 2023
                                        • Spain
                                        #59
                                        Thanks 🥇
                                        • Geralds888
                                          • Apr 2023
                                          • 9
                                          • Ukraine
                                          #60
                                          This is the latest version from lenovo, try it and let me know.
                                          Hi there. Such a problem
                                          After updating my laptop ... The WI-FI adapter disappeared everywhere and the keyboard does not work at all in Windows itself. Everything works in the bios itself. Changed the update from the site, it did not help.
                                          Product Name: Lenovo V15-ADA
                                          Bios Version : E8CN36WW
                                          EC Version : E8EC36WW
                                          MTM: 82C70065CK
                                          Please help me
                                            Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                            09-07-2024, 05:00 AM
                                          • jendkkd jeje
                                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                            by jendkkd jeje
                                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                            10-11-2024, 03:12 PM
                                          • joven016
                                            Lenovo Ideapad S145 need working bios HELP!!
                                            by joven016
                                            Problem is blinking power led only
                                            i don't know exactly if it's s145-15igm or s145-14igm
                                            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                            Already tested some of posted bios here
                                            S145-14igm - success but invalid serial and not booting on OS
                                            S145-15igm - success with serial and some other info in bios but still not booting on OS
                                            already tried installing new windows but always booting on bios setup
                                            windows installer flash drive detected on...
                                            08-21-2025, 10:55 PM
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • mximiliandz
                                            help bios lenovo ideapad s145-14iil type 81w6
                                            by mximiliandz
                                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                            06-20-2025, 06:50 AM
