Lenovo IdeaPad 3 15ADA05
Re: Lenovo IdeaPad 3 15ADA05
hi. where is located serial and windows key in bios file. try find location but not luck. can you help me please. Thank You
my file added.
Lenovo IdeaPad 3 14ADA05
NM-C821
REV : 1.0Attached FilesComment
There's no OEM Windows Key in your dump file.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
The windows key is in the bios (of course it is encoded) TNMBD-82VXC-XXXXX-WC97G-XXXXX, and the serial number is PF1SM4RCComment
try the bios from post #29..it is for the following laptops..V14-ADA, V15-ADA, ideapad 3-14ADA05, ideapad 3-15ADA05, ideapad 3-17ADA05..if it doesn't work you have another problem..don't forget to make a copy of the original bios of the laptop..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hi, I have successfully flashed the bios with the one provided earlier in the thread and the laptop turned on. However, in BIOS the MTM, Lenovo SN, UUID Number and the other fields regarding the laptop on the main screen are empty.
IdeaPad 3 15ada05
SN PF272AZ5
MTM 81W10097BM
Factory ID JVHFC1
MO PF9XB0418028Attached FilesComment
IdeaPad 3 15ada05
SN PF272AZ5
MTM 81W10097BM
Factory ID JVHFC1
MO PF9XB0418028----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hi guys, i've a problem with one 15ADA05, sometimes won't boot the OS.
If the problem is the bios, the serial number is: PF294VE5
Thanks for all, guysAttached FilesComment
I am working on a 17ADA05 NM-C821, I tried putting a bios file with integrated ram disabled, and didn't work, I tried to put my original bios again in the chip but it's not working either, any ideas, this is my original bios file.Attached FilesComment
Hi there. Such a problem
After updating my laptop ... The WI-FI adapter disappeared everywhere and the keyboard does not work at all in Windows itself. Everything works in the bios itself. Changed the update from the site, it did not help.
Product Name: Lenovo V15-ADA
Bios Version : E8CN36WW
EC Version : E8EC36WW
MTM: 82C70065CK
Please help meComment
This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...09-07-2024, 05:00 AM
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by Popel1083Hi,
I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
SN: QB08570065
MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02-
- Loading...
