Lenovo V110-15ISK Unlocked BIOS Password
  • peste
    • 13422
    • ROMANIA
    Re: Lenovo V110-15ISK Unlocked BIOS Password
    Originally posted by r_phan
    Hi guys, I hope I can ask your help in this thread.
    I have a V110-15ISK (Type 80TL) laptop with a password protected BIOS and a dead HDD. I tried to replace said HDD with a modern SSD, but it is not recognised by the system. It probably needs some settings changed in the BIOS, but I can't get in.
    I tried flashing some of the bios files on offer on this site using WinFlash64.exe which I got from Lenovo's site, but it errors out on me with error 233 (ERROR 233 - Only secured capsule is allowed on a SecureFlash system!).
    Do I need another application to flash the file?
    Thanks for your help!
    post the original bios ..
    • r_phan
      • Jun 2022
      • 5
      • Nederland
      Originally posted by peste
      Thanks. I've been trying to figure out how to successfully dump this laptops BIOS, but I'm lost at which tools to use and the LENOVO section is not clear about this. Can I dump (and/or flash) the bios using command line tools, or will I always need a dedicated external usb programmer?
      [edit]
      Sorry for my ignorance, I'm not very familiar with externally messing with BIOS chips.
      I actually found a CH341a programmer lying around in one of my drawers which I think is suited to the job. And I think I successfully managed to dump my v110s BIOS with it, it is attached to this post. If someone would be so kind as to have a look?
      Last edited by SMDFlea; 04-05-2023, 08:43 AM. Reason: Attachments cleanup,server space low.
      • AAAC
        • Jan 2020
        • 458
        • Mexico
        @r_phan
        Your BIOS file seems to be incomplete.
        • r_phan
          • Jun 2022
          • 5
          • Nederland
          I tried again, this one verified in the programmer as being the same. Any better?
          • AAAC
            • Jan 2020
            • 458
            • Mexico
            @r_phan
            The file looks a lot better, which software did you use with CH341A programmer? as sometimes the software being used with CH341A corrupts readings/writings to BIOS chip.
            Use this file ONLY if you have verified dump against BIOS chip contents (as you mention in previous post):
            • Aditya11ttt
              Adi
              • Feb 2019
              • 186
              • India
              #26
              Use Asprogrammer Software it works best with ch341a without any issue.
              https://drive.google.com/drive/folde...7NEwpzq_k7aaUZ
              • r_phan
                • Jun 2022
                • 5
                • Nederland
                #27
                Thank you both.
                I think I already messed something up, as the laptop is no longer booting after dumping the BIOS using the USB programmer.
                I used Ch341a USB Programmer Software V1.40.0.0 (SiberiaProg) as my tool.
                I'll try your software, but I think it's already too late.
                • r_phan
                  • Jun 2022
                  • 5
                  • Nederland
                  #28
                  I thought I had ruined the bios chip, but using Asprogrammer I managed to flash it back into life. I did not use my own bios dump as I did not trust it, but found a .bin for the same model in another thread and... it boots again and the password is gone.
                  Very happy. Sorry for being a total moron going about this, but you guys pointed me in the right direction. Thanks!
                  • Skiphixxz
                    • Aug 2022
                    • morocco
                    #29
                    hello guys sorry for bothering you all but i just bought a Lenovo V110 15isk form a random person from facebook market place and i noticed it has a HDD inside so i tried to replace it with a much faster SSD. i prepared my windows usb, i opened up the pc and switch the 2.5" drive with SSD then when i plugged my usb it didn't work. i went to the bios so i can switch it to legacy mode than i found it is protected with a password. Now all i ask from you guys is to walk me trough how i can extract my bios and give it to you so you could maybe crack the password and also show me how to flash the new one. please help me....
                    PS: sorry for my language mistakes.
                    • Ezis
                      • Sep 2022
                      • 7
                      • Latvia
                      #30
                      Lenovo V110-15ISK BIOS password help
                      Hello!
                      I need help resetting BIOS password on this laptop.
                      Motherboard:
                      LV115SK MB
                      15277-1N
                      448.08B01.001N
                      BIOS chip is from manufacturer GIGADEVICE:
                      GD25B64CSIG on the IC, datasheet show that it is GD25B64C but
                      I got CH341A and read IC with ASprogrammer, it detected two options:
                      GD25Q64 and GD25Q64B so i took the dump from GD25Q64 and uploaded here.
                      Should i read the other detected IC and upload it as well? which one is the correct one?
                      can anybody help me with this?
                      please be soft on me as i am still learning
                      Last edited by SMDFlea; 04-05-2023, 08:44 AM. Reason: Attachments cleanup,server space low.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12268
                        #31
                        Re: Lenovo V110-15ISK BIOS password help
                        Originally posted by Ezis
                        Hello!
                        Motherboard:
                        LV115SK MB
                        15277-1N
                        448.08B01.001N
                        You have selected the correct bios chip but your bios file is corrupted, you need to read the chip again.
                        ​https://www.badcaps.net/donate
                        • Ezis
                          • Sep 2022
                          • 7
                          • Latvia
                          #32
                          Thank you for Your quick response.
                          I've read it again, could you please check if it is still corrupted?
                          Last edited by SMDFlea; 04-05-2023, 08:45 AM. Reason: Attachments cleanup,server space low.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12268
                            #33
                            Apparently there was a change from the previous file but it still crashed.
                            • Ezis
                              • Sep 2022
                              • 7
                              • Latvia
                              #34
                              I appreciate your help!
                              Is it because of CH341A itself or could it be ASprogrammer?
                              I tried two reads with neoprogrammer, but it seems that it also crashes in mid-reading as after read i try detect chip again and it shows that no ic is found.
                              It might be that i need volt mod CH341A to read IC properly?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12268
                                #35
                                The 3rd and 4th read, the 2 files are still different, your programmer either leaves some areas blank or reverses the positions of the regions together, I don't know if this is the fault of CH341A or ASprogrammer.
                                • Ezis
                                  • Sep 2022
                                  • 7
                                  • Latvia
                                  #36
                                  I think it is Ch341A fault, i tried voltage mod mentioned in this forum but i ripped off one pin, so i ordered Ch341A version where you can switch between voltages, will come back with new dump after i receive it, thank you for your help for now.
                                  • Ezis
                                    • Sep 2022
                                    • 7
                                    • Latvia
                                    #37
                                    I got the new Ch341A version and switched to 3.3V and did the read of IC again, but i'm thinking its still corrupted, can someone check that?
                                    • hardware1
                                      • Sep 2021
                                      • 2946
                                      • N/A
                                      #38
                                      Here's your new file, try it and let me know the results.
                                      all donations are welcome,
                                      • Ezis
                                        • Sep 2022
                                        • 7
                                        • Latvia
                                        #39
                                        Sorry for late reply, just got new BIOS chips in mail, programmed and soldered and my computer is working now, thank you very much!
                                        Have a great day
                                        • hardware1
                                          • Sep 2021
                                          • 2946
                                          • N/A
                                          #40
                                          Have a great day
                                          That's good, You're Welcome.
                                          • RMDUiFT
                                            Should I buy a Lenovo Thinkpad E495 with bios password?
                                            by RMDUiFT
                                            Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                            I have a few questions:
                                            • If I would buy this laptop and have
                                            08-25-2024, 09:00 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • lucaszmn
                                            by lucaszmn
                                            Problem:
                                            Initial Findings:
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • baaligoga
                                            Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                            by baaligoga
                                            Good day, everyone!
                                            I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                            I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                            05-20-2023, 09:48 AM
                                          • darknwo
                                            Bios password Lenovo Legion 16IRX8H
                                            by darknwo
                                            Hi, can someone help me please with the removal of the bios password of this dump.
                                            Someone desoldered the bios chip, tried several "methods" but with no luck, and he gave me the dump to try to search some help.
                                            For now he deleted more things and bios password is gone but laptop doesn't show serial, model etc.
                                            Also, I updated bios to latest version, when he will write the dump again without password, it should be better to put back the old version that was orignally or doesn't matter? Because from what I've read this laptop has 3 bios chips, don't know if has...
                                            10-05-2024, 10:40 AM
