Hello , can some one help me in getting Bios for dell xps 9560 with out service tag and password. The bios should not have service tag and i will update the tag.
Re: Bios for dell xps 9560
Hello can anyone clean the ME region for a Dell XPS 9560 notebook. Many ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
​https://www.badcaps.net/donateComment
Thanks for the link.
I know how to clean the ME region SMDFlea showed it very nicely in this link.
https://www.badcaps.net/forum/showthread.php?t=88533
I tried to clean this BIOS with Fit Version 11.0.0.1191 11.0.0.1202 11.6.10.1196 11.8.86.3877 but every time an error message appears.
I can't find any version with 11.0.01178, no idea if it even exists.
If anyone has the version that would be great.
Many thanks ....Attached Filesif you find these attachements useful please consider making a small donation to the site
There`s something wrong with the ME region.Besides,the service tag in your bios is 7GDXF72 its from an XPS 9550 not 9560. According to the product specs at Dell support it shipped with ME disabled (It isn`t really disabled,only the AMT part of it is). This bios has the exact same spec -> https://www.badcaps.net/forum/showpo...4&postcount=10 .If you want to experiment you can extract the ME region from that bios and copy it to yours using a hex editor or an old version of UEFITool, after that FIT works ok, but no need to clean it again anyway,but you could have copied an initialised ME region and then cleaned it.If you want to keep your original service tag/key etc you can copy the DVAR area from your backup to the new bios using a hex editor.There is no service tag/key in the ME_Clean biosThanks for the link.
Thank you for the explanation and your help.There`s something wrong with the ME region.Besides,the service tag in your bios is 7GDXF72 its from an XPS 9550 not 9560. According to the product specs at Dell support it shipped with ME disabled (It isn`t really disabled,only the AMT part of it is). This bios has the exact same spec -> https://www.badcaps.net/forum/showpo...4&postcount=10 .If you want to experiment you can extract the ME region from that bios and copy it to yours using a hex editor or an old version of UEFITool, after that FIT works ok, but no need to clean it again anyway,but you could have copied an initialised ME region and then cleaned it.If you want to keep your original service tag/key etc you can copy the DVAR area from your backup to the new bios using a hex editor.There is no service tag/key in the ME_Clean biosComment
Dell xps 9560 need bios
Hi everyone i need bios for Dell xps 9560
s/n=2GJGNH2
I DONT HAVE BACKUP BIOS
Error is no display turn on for 1 minut and turn off
The laptop was fine, it showed a Tpm error. When I tried to reprogram the bios, ic not read dead, I find another chip from the internet.Comment
Hello. I have some issues with Dell XPS 15 9560 tag 4Z7GMH2
Laptop turns on, black screen, no error code. Display test works.
There's original bios dump
Cam00/01 la-e331p rev 2.0(a01)Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello all, I have a blown thunderbolt 25q80dv chip I think its the thunderbolt anyway, Has anyone got a file they can share please.
Its model CAM0001 LA-E331P, Thanks.Attached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Try this oneQR
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by trix11I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
- https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
- Dell Precision T1650 mid tower Workstation
- Xeon E3-1225 V2
- 32Gb PC3-12800E RAM
- 4Tb SATA HDD
- motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
I see now that others have experienced like issues e.g.:
- https://www.dell.com/community/Prec...-
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
- Loading...
