EDP51 EDB51 LA-H331P REV 1.0(A00) bios needed
Re: EDP51 EDB51 LA-H331P REV 1.0(A00) bios needed
https://forum.laboneinside.com/viewtopic.php?t=9927 -
Attached FilesComment
If it is still actual...Comment
Could anyone assist me in unpacking this into a .bin file?Attached FilesComment
If that doesn`t work for you try this https://www.badcaps.net/forum/troubl...31#post3340731 volinakis ,your super guide copied to a new thread https://www.badcaps.net/forum/troubl...ilities-my-wayComment
help me fix bios file
service tag DJM9M63
LA-H331P REV 1.0Attached FilesComment
by tommy97The laptop originally came in with a no power issue. After replacing the battery with a genuine one, it worked fine for 2–3 days, but then started working only on the charger. Shortly after, it stopped powering on completely.
I have tested with another genuine charger and battery – same result. When connecting the charger, the indicator light turns on but goes off after 2–3 seconds. On battery, the laptop sometimes powers on briefly (about 1 minute) until the battery discharges.
During diagnostics, I found unusual readings on PQ200 and PQ1902 – there is a dead short... -
by saisoni20Hello everyone,
I have problem with backlight problem with DELL XPS 9570 EDP51 EDB51 LA-H331.
I have 13V on inv_pwr_src as attached picture.
Someone can help me to resolve the problem?... -
by KarlfoxmanIll give you some background first,
My work laptop had some liquid damage, I tried to repair it but it was proving to be a very long task. So I bought another motherboard (Faulty from Ebay and decided to attempt to get that one working)
I've made some progress on it, fixed two problems.
No AC charging (Fixed by replacing a resistor around the current sensing)
Missing voltage on NCP81215 VRMP
The power up sequence stops at getting +VCC_CORE, +VCCGT and DDR_DRAMRST#.
I have a scope to look at the PWM outputs to the outputs:... -
by BillyDHello,
Does anyone have the Schematic for EDP51 EDB51 LA-H331P REV 1.0?-
Channel: Schematic Requests ONLY!
by karim011Hi everyone. Plz needed bios file For Acer Nitro N50-620
- Motherboard DIB56L 202019-1 348.0EZ07.0011-
- Loading...
