EDP51 EDB51 LA-H331P REV 1.0(A00) bios needed
  • jacospama
    • Aug 2019
    • 245
    • Ghana
    • 22170
    Re: EDP51 EDB51 LA-H331P REV 1.0(A00) bios needed
    https://forum.laboneinside.com/viewtopic.php?t=9927
    • jacospama
      • Aug 2019
      • 245
      • Ghana
      Thank You Sir. but the site you gave me , one was able to for me . but it keeps on freezing. Mine was giving me blue screen error when am trying to install windows os, it has never given me the chance to install windows os, not even the previous one so i have attached the original dump. please repair it for me if necessary. Thank you.
      • Ihrist
        • Aug 2018
        • Ukraine
        If it is still actual...
        • jacospama
          • Aug 2019
          • 245
          • Ghana
          thank you. it worked
          • niggi
            • May 2016
            • 210
            • UAE
            brother i need this plz
            • amintvn
              • Mar 2021
              • 27
              • i.r iran
              hi i want bios for dell precision 5540
              board number: la-h331p rev:1.0
              service tag: 7228q13
              this laptop freeze screen when install intel hd driver but hdmi screen is ok
              • piszpunta
                • Jan 2019
                • 260
                • poland
                Could anyone assist me in unpacking this into a .bin file?
                  • 22170
                  Search the forum for PFS Extractor
                  • piszpunta
                    • Jan 2019
                    • 260
                    • poland
                    I have used this tool multiple times; unfortunately, in this case, I am unable to do it.
                      • 22170
                      PFS Extractor 4.9 extracts it ok for me https://www.badcaps.net/forum/troubl...16#post1683816
                      If that doesn`t work for you try this https://www.badcaps.net/forum/troubl...31#post3340731 volinakis ,your super guide copied to a new thread https://www.badcaps.net/forum/troubl...ilities-my-way
                      • chelsea1155
                        • 36
                        • vietnam
                        help me fix bios file
                        service tag DJM9M63
                        LA-H331P REV 1.0
                        • arslansharif
                          • Oct 2016
                          • 47
                          • pakistan
                          Thanks its working 100%
                          • testinglaptops
                            • Oct 2022
                            • 86
                            • United Arab Emirates
                            THANKYOU. TESTED 100% WORKING. FAST DISPLAY AND SOLVED HNGE AT LOGO ISSUE
                            • tommy97
                              Dell XPS 15 7590 (EDP51-EDB51 LA-H331P) - Does not charge
                              by tommy97
                              The laptop originally came in with a no power issue. After replacing the battery with a genuine one, it worked fine for 2–3 days, but then started working only on the charger. Shortly after, it stopped powering on completely.
                              I have tested with another genuine charger and battery – same result. When connecting the charger, the indicator light turns on but goes off after 2–3 seconds. On battery, the laptop sometimes powers on briefly (about 1 minute) until the battery discharges.
                              During diagnostics, I found unusual readings on PQ200 and PQ1902 – there is a dead short...
                              08-21-2025, 03:35 AM
                            • saisoni20
                              Dell xps 9570 edp51 edb51 la-h331 - backlight problem
                              by saisoni20
                              I have problem with backlight problem with DELL XPS 9570 EDP51 EDB51 LA-H331.
                              I have 13V on inv_pwr_src as attached picture.
                              Someone can help me to resolve the problem?...
                              03-24-2023, 04:57 PM
                            • Karlfoxman
                              Dell XPS 7590 (EDP51/EDB51 LA-H331P)
                              by Karlfoxman
                              Ill give you some background first,
                              My work laptop had some liquid damage, I tried to repair it but it was proving to be a very long task. So I bought another motherboard (Faulty from Ebay and decided to attempt to get that one working)
                              I've made some progress on it, fixed two problems.
                              No AC charging (Fixed by replacing a resistor around the current sensing)
                              Missing voltage on NCP81215 VRMP
                              The power up sequence stops at getting +VCC_CORE, +VCCGT and DDR_DRAMRST#.
                              I have a scope to look at the PWM outputs to the outputs:...
                              01-21-2024, 08:01 AM
                            • BillyD
                              EDP51 EDB51 LA-H331P REV 1.0 Schematic
                              by BillyD
                              Does anyone have the Schematic for EDP51 EDB51 LA-H331P REV 1.0?
                              10-10-2021, 01:34 PM
                            • DeXXter
                              Replacing SOC SRK08 clean me needed?
                              by DeXXter
                              Hello, so I replaced a soc SRK08 (i3-1115G4) on a hp 14-dq because the 1.8v power supply was shorted and the pch was gone and I installed a SRK05 (i5-1135G7) that I had at hand. And I was wondering if a clean me region is needed after replacing the chip, I usually do this on laptops with separated pch, but with a soc (cpu and pch together) I have no idea. Normally I wouldn't ask this, but I have only the motherboard, no screen nor the adapter, and after I fix this I have to send it to another region so if someone knows about this, some help would be apreciated.
                              Note: After doing all...
                              11-19-2025, 03:16 AM
