Thinkbook 15-IIL bios DALVACMB8D0
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Re: Thinkbook 15-IIL bios DALVACMB8D0
details on laptop: Lenovo Thinkbook 14 IIL, Model name: 20SL, Factory ID: CS20, S/N: LR0D0C6C, MO: LRN0B032700B, MTM: 20SL001NAK
Laptop problem: i shut it down a couple of days ago and thats it. pretty normal shut down after normal use. now it doesnt POST. power light comes on, charging LEDs respond to charger and charges battery but no HDD light. HDD and Fan spin but thats it nothing else happens no display either, not even backlight...
Things i already tried: reset bios cmos, did the whole power drain by removing battery, tried different RAM, different HDD, nothing worked. The CPU feels warm like its on but other than that nothing else happens.Comment
You can use the file from Post #20 and it will works fine. But you have to take a backup from your BIOS chip before re-flash it, to keep the DMI save.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Thank you! I will try that dump and see if it fixes my issue.Comment
Hello again.
The bios did not work. I tried 2 files and none work. I assume my original bios might have been okay because I think this is a hardware issue now. After measuring voltages I found abnormal voltage on the DCIN rail. 9.1v instead of 20v. Unless I am missing something there.
Anyway, thanks for the help, but I think I should move my issue to a different thread on hardware troubleshooting.Comment
Hello again.
Yes, it could be a Hardware issue and you can continue in the hardware section.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
LR0EGV0H
ThinkBook 15-IIL Laptop - Type 20SM
Makine Tipi: 20SM
with ati gpu all bios files in these list not starting the computer.please helpComment
Read the thread before asking questions please.
https://www.badcaps.net/forum/troubl...96#post1835796
Hello Dears, any one help me I need bios for ThinkBook 14-IIL DALVACMB8D0 REV D.
old bios, and update from website.
Thanks in advanced.
plzzzz
and im asking if the bios of 15iil is the same of 14ill
Post your request in the 14-iil thread https://www.badcaps.net/forum/troubl...ok-14-iil-bios .Post your bios backup and laptop serial number as well
Hello! I'm new to BIOS modding and want to unlock thinkbook15 bios (and disable writeprotect so that I can flash internally).
Here's some detailed information:
BIOS Version: Phoenix DJCN31WW
Backed Firmware: Attached to this post
I have tried several methods(ru.efi,setup_var.efi,modding using ifrextractor and uefitool by longsoft [ I know something has been "suppressed", but have no idea how to "unsuppress" them. ] ), but due to my poor knowledge, none of them worked.
I would appreciate it if anyone can offer some advice or help mod the firmware.Attached FilesComment
post the S/N, the original bios of the laptop, the motherboard model, the full name and model of the laptop,
etc.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Machine Model Name: Lenovo Thinkbook 15 IIL
CPU: Core i7 1065G7 @1.30GHz 4 cores
GPU: Intel Iris Plus Graphics (128MB,Lenovo)
RAM: Skhynix 16GB DDR4 2667MHz
Storage: NVME INTEL HBRPEKNX9292AL (512GB)
Motherboard: Lenovo LNVNB161216 (IceLake SOC)
Sorry for undetailed information.Comment
Hello I have one with a password lock. SN: LR0DDYGS . I tried bios from post 20 but didn't work. Thanks.Attached FilesComment
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by DiddiAbRecently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...-
by Chris2025Hello BIOS gurus,
Laptop in trouble is:
model: ThinkBook 14p G2 ACH
MO: PF9XB1C20495
MTM: 20YN0023AU
SN#: PF3GVSPN
Current issue: laptop react on power button, battery charging, fan turning on/off, no CAPS LOCK response on pressing, no system boot and screen remains black.
What was done so far - connected external monitor via HDMI / USB-C, system reset, BIOS reset - all to no avail.
Also loaded random BIOS for this model from internet - PC booting up but have odd issues when I try to reinstall Win11 on it.
Would...-
by Chris_standHello,
i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
But the...-
by Magician1981Greetings,
I kindly request assistance with the following. My lenovo thinkbook 15 g2 itl has the following symptoms:
- blank screen
- no post
- fan running at 100%
- unable to enter bios
- on powerup with pinhole method the led's of the power button+esc key+caps key lights up green for a brief moment
I've tried:
- holding power button >30s while unplugged from ac+unplugged battery+unplugged cmos battery
- above with pin hole method >10s
Was willing to try:
- obtaining bios .bin file...-
- Loading...
