T2 Chip Programmer Tool
	This topic is closed.
 Re: T2 Chip Programmer Tool
 Hello, I brought a T203 programmer a little while ago, programmed the chip but did not realise at the time that the jaibreak was not compatible with Monterey.
 Does anyone know, if or when a new CheckM8/Mina Jailbreak for Monterey will be available? And if so will I have to pay for it?
 Thanks in advanceLast edited by Terry011; 06-06-2022, 11:53 AM.Comment
 Everyone's waiting for the next Checkrain update, which is indefinite at the moment.Hello, I brought a T203 programmer a little while ago, programmed the chip but did not realise at the time that the jaibreak was not compatible with Monterey.
 Thanks in advance
 You can use Monterey on a jailbroken Mac if it was manually installed via bootable usb drive. The iboot version is the only thing that could prevent your jailbreak from working i.e if it's been updated above version 5.5.Comment
 Correct!! I suppose that this device was already activated. After I changed the Serial number to a compatible one as you suggested in the early posts went smooth to bypass the MDM, but can't reach the activation server of apple.. so my guess is that the link that it tries to reach is tied to the Serial number in the T2 chip and the serial number in the ROM. I suppose that I must w8 until the release of the jailbreak for Monterey.Last edited by sinaps1; 06-07-2022, 02:16 PM.Comment
 Probably worth a good read from the first post of this thread to the last.
 There's a photo of a Mac booting into recovery mode which will tell you whether the Mac is on the old bridgeOS version or newer.Comment
			by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
			by baletakHi,
 had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
 I have updated laptop model number.
 1) I did not find the way to update laptop serial number - I have this one.
 2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
 Hope to find someone to help me with this as I am hitting dead end at the moment.
 Many thanks
 Miro-
							Channel: BIOS Requests ONLY!
			by SMDFleaAdding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
 and once you do find them there`s a few crucial steps missing.
 Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
 Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
 After adding the chip save the xml file and copy it to the root directory of the...-
			by SMDFleaCommon SPI bios chip programming Questions and Answers
 Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
 A: If you can`t read from it how do you expect to write to it ?.
 Q: Why is my bios chip unreadable ?.
 A: The programmer is faulty or has a worn or broken zif socket.
 The USB cable is frayed,connector pins worn or some other physical damage.
 Not enough amperage or voltage to power the programmer properly.
 Bad...-
 09-02-2021, 04:40 PM
			Long story short:
 - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
 - gave the computer to his son a couple years later
 - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
 - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
 (seems like the story was not that short)
 He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
- Loading...
