HP ENVY 15-j040el bios dump
  • mangus
    • Nov 2017
    • 11
    • Lietuva
    Maybe someone has bios dump of this laptop? I accidentally flashed with f72 version which I think is from j100x series and cannot back to original latest or any other bios which made for this laptop. Maybe someone has dump from it?
  • peste
    • Dec 2016
    • 12882
    • ROMANIA
    Re: HP ENVY 15-j040el bios dump
    try this ... the laptop has two bios versions, try one at a time, if it works enter the DMI information ..
    • mangus
      • Nov 2017
      • 11
      • Lietuva
      one worked, did not know exactly which, because I dumped both to separate chip and soldered. But now I have problem with dmi information. How to enter them, if I don't know them. I still have original dump, so probably all information will be in that dump. Probably can use HP BCU to enter all info.
      • peste
        • Dec 2016
        • 12882
        • ROMANIA
        trythis .. if it doesn't work post the original bios ..
        https://www.youtube.com/watch?v=9T57ktw8n3Y
        • mangus
          • Nov 2017
          • 11
          • Lietuva
          trythis ..
          tried to follow procedures but that config file doesn't give me option to insert my numbers. Looks like the same config file I get when I tried to use HP BCU utility. I attached config file
          • peste
            • Dec 2016
            • 12882
            • ROMANIA
            I can't tell you why you don't have the other optins, I didn't have these problems on any laptop where I wanted to change the DMI information ... I use the same program ... try this too ... you still have the original bios of the laptop ???
            https://www.youtube.com/watch?v=rP3A3HWM_-Q
            • mangus
              • Nov 2017
              • 11
              • Lietuva
              Yeah I have dump of original bios chip. I may try manually add these line to config, maybe it will work. Otherwise just try set manufacturing mode to lock. At this moment, laptop show that model name is hp pavilion
              • mangus
                • Nov 2017
                • 11
                • Lietuva
                To end this thread, I set in config dmi information and also set manufacturer programing mode to lock. None of dmi information was saved in bios but now it doesn't show that error message, so I think I leave this way and I won't bother my head about that information is not correct
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                  by haitham sharabati
                  Hello engineers 😀,
                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                  💀 Problem:😅
                  - Device shows “Administrator Password”...
                  08-07-2025, 04:54 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • Kenzi
                  Cannot modify HP Envy 15 ep-00008na BIOS
                  by Kenzi
                  I'm trying to modify my BIOS to unlock the advanced menus and unlock the processor power limits. The first thing I have tried is reading the BIOS from the laptop and opening it up in amibcp, and changing the advanced menu to User. However, no matter what tiny change I make to the BIOS, when I flash it back to the laptop with a programmer it says there is corruption and the BIOS needs to be recovered.
                  I've also tried rolling back the BIOS to an older version. I made the mistake of updating to the latest version and now I cannot even edit the CFG and OC...
                  11-09-2023, 05:22 AM
