HP ENVY 15-j040el bios dump
  • mangus
    • Nov 2017
    • 11
    • Lietuva
    Maybe someone has bios dump of this laptop? I accidentally flashed with f72 version which I think is from j100x series and cannot back to original latest or any other bios which made for this laptop. Maybe someone has dump from it?
  • peste
    • 13921
    • ROMANIA
    Re: HP ENVY 15-j040el bios dump
    try this ... the laptop has two bios versions, try one at a time, if it works enter the DMI information ..
    • mangus
      • Nov 2017
      • 11
      • Lietuva
      one worked, did not know exactly which, because I dumped both to separate chip and soldered. But now I have problem with dmi information. How to enter them, if I don't know them. I still have original dump, so probably all information will be in that dump. Probably can use HP BCU to enter all info.
      • peste
        • 13921
        • ROMANIA
        trythis .. if it doesn't work post the original bios ..
        https://www.youtube.com/watch?v=9T57ktw8n3Y
        • mangus
          • Nov 2017
          • 11
          • Lietuva
          trythis ..
          tried to follow procedures but that config file doesn't give me option to insert my numbers. Looks like the same config file I get when I tried to use HP BCU utility. I attached config file
          • peste
            • 13921
            • ROMANIA
            I can't tell you why you don't have the other optins, I didn't have these problems on any laptop where I wanted to change the DMI information ... I use the same program ... try this too ... you still have the original bios of the laptop ???
            https://www.youtube.com/watch?v=rP3A3HWM_-Q
            • mangus
              • Nov 2017
              • 11
              • Lietuva
              Yeah I have dump of original bios chip. I may try manually add these line to config, maybe it will work. Otherwise just try set manufacturing mode to lock. At this moment, laptop show that model name is hp pavilion
              • mangus
                • Nov 2017
                • 11
                • Lietuva
                To end this thread, I set in config dmi information and also set manufacturer programing mode to lock. None of dmi information was saved in bios but now it doesn't show that error message, so I think I leave this way and I won't bother my head about that information is not correct
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  by haitham sharabati
                  Hello engineers 😀,
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  💀 Problem:😅
                  08-07-2025, 04:54 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
