HP EliteBook 845 G7 BIOS Pass
    Re: HP EliteBook 845 G7 BIOS Pass
    Originally posted by kangajoe View Post
    I have found that much of the information in many forums around this problem have been missing a lot of vital information.
    After my own research and experience I have documented exactly what worked for me.
    I hope that others may find this helpful.
    Thanks i solved the problem with this method using back dump ...
      I wanted to remove the password in my hp elitebook 845 g7, but initially when I unsoldered the W25Q256JV chip (bottom), I broke a pin and I couldn't even make a backup... so I bought a new W25Q256JV chip, I programmed it with one of the bin files already modified by some user in this thread, but the laptop doesn't start and "caps lock" blinks 7 times. Any suggestions? Thank you so much
        i think your laptop is already dead.. the ec and main must be match
          i should try programming both bios and ec, again with someone's already modified bin files. I have programmed only the EC
            Bios lock, i cannot find active region this time i need some help remove bios lock, tnx
              Up
                Need help
                  Need help
                  Try
                    Originally posted by Vesko356 View Post
                    Next - program both spi chips with the corresponding files from the attached archive and you're good to go.
                    I tried to program both the bios and the EC but now the caps lock flashes 7 times. Unfortunately I had to use these files, as I broke the EC chip "25Q256JVEN", so to match both the bios and the new EC, I thought of programming the files of some other computer the same. What should I do? Thanks
                    Edit: the weld is perfect and have been programmed correctly
                      HP EliteBook 845 G7 bios cleared request
                      hey, i'm looking for clean bios and ec dumps, i tried to flash both with files taken in a thread but the laptop won't start and caps lock blinking 7 times (I guess because they are not clean)
                      I don't have the original backup up because the original ec i broke it before i even read it..., so i buy another one!
                      Thank you so much, I'm losing my mind for this laptop!
                      Bios: MX25L25673
                      EC: W25Q256JVEN
                      Motherboard: LINDEN-6050A3147201-MB-A01(A1)
                        Re: HP EliteBook 845 G7 bios cleared request
                        Bios: MX25L25673
                        EC: W25Q256JVEN
                        Please help
                          Bios: MX25L25673
                          EC: W25Q256JVEN
                          I noticed that the new EC chip I bought has a different code... W25Q256JVEM, but the original is W25Q256JVEN. Could this be the cause of the laptop blinking 7 times caps lock? Thanks
                            Bios: MX25L25673
                            EC: W25Q256JVEN
                            Up
                              Hello all, Can someone please unlock this bios, its the original chip
                              Winbond 256mb. I tried RCUnlocker.
                              HP EliteBook 845 G7, Thanks so much.
                                Upload the dump from the second chip (U366-at the back of the board).
                                Become a Badcaps supporter
                                Thanks to all supporters.​
                                  Thanks mate, I will have to wait till I get back from Spain
                                  I have a wedding to go to, I will upload the file when I am back.
                                  busy packing today. Thanks again mate.
                                    You're welcome! Have fun at the wedding!
                                      Hello mate I am back now, Just got around to reading this chip, Here is the second dump, Thanks mate.
                                        Program this chip only, leave the other as is. At fist boot enter the bios and reset security settings to default:
                                          Thank you very much for being so quick.
                                          Thanks.
