HP EliteBook 845 G7 BIOS Pass
    Re: HP EliteBook 845 G7 BIOS Pass
    Originally posted by Dan20701 View Post
    Thank you very much for being so quick.
    Thanks.
    You're welcome.
    Please consider donation in support of the "Bios Request" section of the forum.
    Become a Badcaps supporter
    Thanks to all supporters.​
      Is there a definitive method for clearing these passwords? I did try clearing the nvramactive area on the 32mb dump and the bios log persists. If i understood the previous post, this is the ec chip and should only be necessary to clear on this chip (u367)
      Is it situational?
        help me to remove password bios hp 845 g7
            thanks bro its working ...
              Could you please help me remove the BIOS password on my HP Elitebook 845 G7. I tried modifying the files myself, but it didnt seem to work. Here are the original BIN files for both the bottom and top chips. If you need any additional information or files please let me know. Thank you for your time.
                  Re: HP EliteBook 845 G7 bios cleared request
                  Originally posted by dariuxzy View Post
                  hey, i'm looking for clean bios and ec dumps, i tried to flash both with files taken in a thread but the laptop won't start and caps lock blinking 7 times (I guess because they are not clean)
                  I don't have the original backup up because the original ec i broke it before i even read it..., so i buy another one!
                  Thank you so much, I'm losing my mind for this laptop!
                  Bios: MX25L25673
                  EC: W25Q256JVEN
                  Motherboard: LINDEN-6050A3147201-MB-A01(A1)
                  Ugh I just did the same stupid effing mistake. Ground pin busted off on the EC. can't find any remnants of the pin to try and attempt reviving the chip. I'm under the impression that I might be able to flash the bios and ec once I replace the ec to get it running again? How screwed am I here?
                  And here I thought I would have a nice afternoon reviving this system.
                    Originally posted by kangajoe View Post
                    I have found that much of the information in many forums around this problem have been missing a lot of vital information.
                    After my own research and experience I have documented exactly what worked for me.
                    I hope that others may find this helpful.
                    Ok, so I was able to salvage another system to try this unlock. I followed all the steps, and bam, it DID remove the password, but now I have the endpoint security controller error. I'm assuming that's why people here request both bios to do the unlock? what should I modify in my main bios to remove this error?
                    I've attached a dump of both top and bottom chips if anyone can unlock them for me. I tried comparing to other bios and even though I find the area's commonly modified it doesn't seem to be what I need to modify on mine? (I have the unedited bottom bin in my zip)
                      thank you
                      Last edited by alfredodinolfo; 09-04-2023, 11:39 AM. Reason: Bios removed, thread hijack.
                        Originally posted by alfredodinolfo View Post
                        Probook 635 G7
                        MB:LINDEN-6050A3147201-MB-A01
                        no video.
                        I programmed both spi (U366_U365 and U367), now video com'in but show error end-point and ask password.
                        attached original dump.
                        Thank your for help.
                        Off topic, this thread is for HP EliteBook 845 G7 only!
                        Read the rules, next time don't hijack threads or you will receive an infraction
                          Sorry i mystake because is same mb code. Remove it if off-topic.
                            If a thread title has only a laptop model number then only requests for that same model should be made.If a thread title has a motherboard model number only,then any laptop model number can be posted in that thread if the motherboard (including revision etc) is the same.
                              please removed bios password
                                aaaaaaaa
                                  thanks
                                    Originally posted by peste View Post
                                    try this..modify only this bios ... the other one stays the same ..
                                    thanks for this it removed my absolute lock.
                                    I unlocked by myself the bios password in EC and i used this as main and it works.
                                      please help me to unlock
                                      probook 845 g7
                                      advance thanks
                                        probook 845 g7
                                        advance thanks
                                        Serial number ?
                                          Originally posted by hoaca388 View Post
                                          Serial number ?
                                          here sir
                                          SN# 5CG1161239
