asus gl703GS bios
  • Pfudaniel
    • Feb 2021
    • 91
    • Netherlands
    asus gl703GS bios
    Hi bois looking for a asus GL703GS bios to use with programmer!
    any version wil do .
    Thanks in advance, Daniel
  • peste
    • 13850
    • ROMANIA
    Re: asus gl703GS bios
    post the backup of the bios
    • Pfudaniel
      • Feb 2021
      • 91
      • Netherlands
      awsome thanks !
      • peste
        • 13850
        • ROMANIA
        awsome thanks !
        try..
        • ahmetermin
          • Mar 2015
          • 39
          • batman
          try..
          thanks it works nvidia problem
          my bios is ok
          showing up late
          can you clean
          old bios
          https://disk.yandex.com.tr/d/68GELix8DaQ9ag
          • peste
            • 13850
            • ROMANIA
            my bios is ok
            showing up late
            can you clean
            old bios
            try.
            • dhibubabu
              • Dec 2014
              • 55
              • UAE
              i have one GL703GS
              problem is keyboard not working
              all keys not working
              in bios also keys not working
              tested with a new keyboard - not working
              any solution ?
              • pityulix
                • Nov 2021
                • 32
                • Targu-Mures
                Hi,i have Asus GL703GS with intel i78750H and GTX1070.I had to change de Super IO,because it was faulty,the BIOS chip was missing,i found one,programmed it with one bios found on my pc.
                The problem is,that takes too long to post,and when it does,its working good everything,but the Serial Number is missing on the BIOS post.I tried the one from above,its posting fast,but i cant install driver for gtx,my one is ok to install GTX but as i mentioned,takes too long to post and doesnt appera serial number on bios,so i need help from you,to fix my bios.Thank you a lot in advance.
                Asus model GL703GS-E5039R
                SN: J9NRCX03R87939A
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12425
                  SN: J9NRCX03R87939A
                  SN: J9NRCX03R87939A​
                  • pityulix
                    • Nov 2021
                    • 32
                    • Targu-Mures
                    Working Fine.Thank You very much for help.
                    • ninsa
                      • Dec 2018
                      • 30
                      • republica dominicana
                      POWER ON, NO DISPLAY
                      MODEL GL703GS-DS74
                      SERIE J9NRCX01X53537B
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12425
                        MODEL GL703GS-DS74
                        GL703GS
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
