Dell Latitude E7480 CXWHP BIOS??? TPM not detected...
  • feherhollo
    • Nov 2019
    • 110
    • Hungary
    I have Dell Latitude 7480 motherboard with TPM chip not detected fault. Bios update disabled the TPM chip and no longer have the option in the BIOS.
    Please share your original dump if you have DP/N: 0CXWHP part numbered motherboard with 25Q128FV chip. I have tried reflash bioses from other E7480 boards but no luck, computer not booted and/or working properly.
    If you have skills for re enable the TPM in my current dump also let me know.
    • 22287
    Re: Dell Latitude E7480 CXWHP BIOS??? TPM not detected...
    Post your bios backup .
    • feherhollo
      • Nov 2019
      • 110
      • Hungary
      Here is my working original dump! Boot with the following error:
      • feherhollo
        • Nov 2019
        • 110
        • Hungary
        Hope there are some solution available...
        • CornholioGSM
          • Feb 2014
          • 265
          • CZECH
          hmmmm...same problem by me on E7280 - tpm not detected
          Still no solution?
            • 22287
            Still no solution?
            Post your backup.
            • trufoldino157
              • Aug 2020
              • 19
              • Russia
              Hi.
              Has anyone solved this problem? If so, please describe the solution.
              • feherhollo
                • Nov 2019
                • 110
                • Hungary
                This is not a BIOS related problem. It is a hardware problem of faulty chip or TPM chip firmware. The solution is to remove the whole TPM functionality from BIOS dump and reflash the BIOS chip.
                Still not tested, because I have replaced these mobos under warranty so don't have proper success on that, but can try...
                • Aditya11ttt
                  Adi
                  • Feb 2019
                  • 192
                  • India
                  Originally posted by trufoldino157
                  Hi.
                  Few things you can try
                  1.Update or Downgrade the bios Version
                  2.Me Clean
                  3.Try another working bios
                  4.Disable PTT protection during me clean which disable automatically when you do meclean.
                  5.If you know exact string and can remove complete TPM part from bios.
                  6.If there is TPM Update from model officially try to install and try the luck.
                  7.There is ways to enable TPM from windows also,
                  8.Complete remove Tpm module from board (Assumption Not tested)
                  These are few steps can try for solving TPM cases
                  PS Some of them have been working in some of the model and some are not still needs to be tested.
                  If anyone wants to add something to list most welcome.
                    • 22287
                    The first thing to try is a new CMOS battery.
                    A few more suggestions here https://mrtechbot.wordpress.com/2019...tialize-error/
                    • Aditya11ttt
                      Adi
                      • Feb 2019
                      • 192
                      • India
                      Yes Thnx for addition!!
                      This is also a valid basic point
                      also in some laptops there is no Cmos batt. But its in Main Battery also try remove the main battery and hold down power button 30 sec and can also try this step too.
                      • Aditya11ttt
                        Adi
                        • Feb 2019
                        • 192
                        • India
                        TPM Issue permanent Solution is change of “TPM” Ic from the another parallel board till now tested in 10+ boards working without errors and after updates also not any issues or error were reported so far !! May be some one else has some more idea do share !!!
                        PS: New TPM chip may work too , we have not tested that practically.
                        • feherhollo
                          • Nov 2019
                          • 110
                          • Hungary
                          Good replies. Thanks
                          • munir100
                            • Dec 2018
                            • 188
                            • uae
                            DELL 7480 Tpm device is not detected alert here is bios file ST -C19C8H2 CAN any one fix this eror thinks in advenced
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12441
                              Latitude 7480
                              Service Tag: C19C8H2
                              • munir100
                                munir100 commented
                                Editing a comment
                                thanks for repaly same problem
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12441
                              Try with version 1.1.2
                              • munir100
                                munir100 commented
                                Editing a comment
                                thanks this one work before this bios file i chang tpm ic but not sceufull thanks for help
                            • dqtech
                              Badcaps
                              • Jul 2018
                              • 641
                              • N/A
                              this working without TPM error
                              • usman wingo
                                • Jan 2017
                                • cameroon
                                I just solved this TPM Problem by flashing another Bin file into the BIOS chip.
                                • mshone
                                  • Jan 2014
                                  • 61
                                  • serbia
                                  Hi, same model, same problem. Dell latitude 7480, service tag 18Q0MH2, TPM is not in listed in bios, during boot a lap give me alert "TPM device is not detected". Tried new version OS, newest BIOS, bud without success. In attachment i added original bios bin. If somebody can help, i would be very gratefull.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12441
                                    Try
                                    • gizaha
                                      by gizaha
                                      02-13-2024, 07:18 AM
                                    • Sathsul
                                      Dell Latitude 5431 issues with dumping bios
                                      by Sathsul
                                      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                      10-28-2025, 07:49 AM
                                    • Godfather79
                                      Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                      by Godfather79
                                      Hello everyone in the community
                                      Dear Sir,
                                      I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                      Problem details:
                                      * Model: Dell Latitude 5520.
                                      * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                      * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                      * Service Tag: (Enter your actual Service Tag from the laptop here)
                                      * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                      11-08-2025, 10:04 AM
                                    • NotEnough
                                      Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                                      by NotEnough
                                      I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                                      What I've Tried So Far:
                                      • Reseated the cables.
                                      • Reinstalled AWCC and AlienFX services.
                                      • Attempted BIOS downgrade but no improvement.
                                      • Inspected ribbon cables for damage.
                                      • Explored the possibility of BIOS or
                                      10-19-2024, 01:34 AM
                                    • mikeybass
                                      by mikeybass
                                      04-23-2025, 04:30 PM
