Dell Latitude E7480 CXWHP BIOS??? TPM not detected...
  • mshone
    • Jan 2014
    • 61
    • serbia
    Originally posted by hoaca388
    Try
    Thanks for your effort, i just tried. At opening screen i do not have anymore "TPM device is missing" message, but system is too slow in boot (i check all RAID-AHCI settings), and somehow, i just lost charging
    In BIOS TPM is still no listed. Tried wit a few chargers with no result. Battery is not charging. Have to check intersil chip...
    • hoaca388
      Badcaps
      • Jan 2022
      • 12322
      Again
      ​https://www.badcaps.net/donate
      • mshone
        • Jan 2014
        • 61
        • serbia
        Again
        Thanks a lot for your effort, but still no TPM listed in bios (not even alert that is missing-thats ok). Unofrtenetely, still not charging. Tried to put all in BIOS on factory reset, without result. Idea is to downgrade bios, but it is not possible without charger.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12322
          Check hardware, my file is older version.
          • mshone
            • Jan 2014
            • 61
            • serbia
            Thanks, i will.
            • bbanana
              Father Land
              • Oct 2021
              • 164
              • Vietnam
              #26
              Thanks, i will.
              here
              • mshone
                • Jan 2014
                • 61
                • serbia
                #27
                Originally posted by bbanana
                here
                thanks, still no charging
                • mshone
                  • Jan 2014
                  • 61
                  • serbia
                  #28
                  Well, i want to inform that bios-es are ok (bbanana and hoaca388) and problem with TPM alert is solved. A second problem with "no charging" is solved too. Simple changed chip charger intersil 88738H. Thanks to all for assistance.
                  • gizaha
                    by gizaha
                    02-13-2024, 07:18 AM
                  • NotEnough
                    Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                    by NotEnough
                    I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                    What I've Tried So Far:
                    • Reseated the cables.
                    • Reinstalled AWCC and AlienFX services.
                    • Attempted BIOS downgrade but no improvement.
                    • Inspected ribbon cables for damage.
                    • Explored the possibility of BIOS or
                    10-19-2024, 01:34 AM
                  • mikeybass
                    by mikeybass
                    04-23-2025, 04:30 PM
                  • Loli Popu
                    DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                    by Loli Popu
                    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                    12-13-2024, 08:29 AM
                  • capoplays
                    Help with BIOS update on Dell G15 5515 after chip replacement
                    by capoplays
                    Hey everyone,
                    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                    When I check the BIOS using the F12 menu Flash...
                    10-24-2025, 06:53 AM
