Dell Latitude E7480 CXWHP BIOS??? TPM not detected...
  • mshone
    • Jan 2014
    • 61
    • serbia
    Originally posted by hoaca388
    Try
    Thanks for your effort, i just tried. At opening screen i do not have anymore "TPM device is missing" message, but system is too slow in boot (i check all RAID-AHCI settings), and somehow, i just lost charging
    In BIOS TPM is still no listed. Tried wit a few chargers with no result. Battery is not charging. Have to check intersil chip...
    • hoaca388
      Badcaps
      • Jan 2022
      • 12441
      Again
      • mshone
        • Jan 2014
        • 61
        • serbia
        Again
        Thanks a lot for your effort, but still no TPM listed in bios (not even alert that is missing-thats ok). Unofrtenetely, still not charging. Tried to put all in BIOS on factory reset, without result. Idea is to downgrade bios, but it is not possible without charger.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          Check hardware, my file is older version.
          • mshone
            • Jan 2014
            • 61
            • serbia
            Thanks, i will.
            • bbanana
              Father Land
              • Oct 2021
              • 164
              • Vietnam
              #26
              Thanks, i will.
              here
              • mshone
                • Jan 2014
                • 61
                • serbia
                #27
                Originally posted by bbanana
                here
                thanks, still no charging
                • mshone
                  • Jan 2014
                  • 61
                  • serbia
                  #28
                  Well, i want to inform that bios-es are ok (bbanana and hoaca388) and problem with TPM alert is solved. A second problem with "no charging" is solved too. Simple changed chip charger intersil 88738H. Thanks to all for assistance.
                  • gizaha
                    by gizaha
                    02-13-2024, 07:18 AM
                  • Sathsul
                    Dell Latitude 5431 issues with dumping bios
                    by Sathsul
                    So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                    The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                    However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                    10-28-2025, 07:49 AM
                  • Godfather79
                    Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                    by Godfather79
                    Hello everyone in the community
                    Dear Sir,
                    I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                    Problem details:
                    * Model: Dell Latitude 5520.
                    * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                    * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                    * Service Tag: (Enter your actual Service Tag from the laptop here)
                    * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                    11-08-2025, 10:04 AM
                  • Godfather79
                    by Godfather79
                    Dear Sir,
                    I need help removing/unlocking the BIOS password on my Dell Latitude 5520 laptop.
                    Problem details:
                    * Service Tag: (HMHJQ93)
                    What I need:
                    Please help me generate a Master Code for the 3FE2 password based on my Service Tag, or for a "Virgin" (completely clean) BIN file without a password for this model.
                    In the attachment...
                    Today, 07:18 PM
                  • NotEnough
                    Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                    by NotEnough
                    I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                    What I've Tried So Far:
                    • Reseated the cables.
                    • Reinstalled AWCC and AlienFX services.
                    • Attempted BIOS downgrade but no improvement.
                    • Inspected ribbon cables for damage.
                    • Explored the possibility of BIOS or
                    10-19-2024, 01:34 AM
