hp probook 440 g7 bios password
  • hoaca388
    Badcaps
    • Jan 2022
    • 11395
    • Viet Nam
    #41
    Re: hp probook 440 g7 bios password
    Originally posted by Amozito
    Hi! I need help with removing password from BIOS. I tried some files I found on this site.. it worked but then I got "Hp endpoint security controller problem" every time I boot.
    Here are the original files.
    Note: the two files you posted in the zip file are the same. It is an EC file. I just wanted to make sure you didn't make a mistake when choosing the file to compress.
    • Amozito
      • Jul 2022
      • Sweden
      #42
      These are the files I got from Gigadevice 25B127DSIG and Winbond 25Q128JVSQ. I used AsProgrammer. Did I miss anything?
      • chucky465
        • Dec 2022
        #43
        Hi need a little help with removing bios password. In the file it contains both original and unlocked.
        • c.o.c.o.
          • Jan 2023
          • türkiye
          #44
          Can anyone help remove password from the 440-g7 attached locked bios, please.
          Thanks in advance.
          • volinakis
            • Jan 2021
            • 2665
            • N/A
            #45
            Thanks in advance.
            read again your chipset or find 2nd chipset on back of mainboard.
            • volinakis
              • Jan 2021
              • 2665
              • N/A
              #46
              the unlocked file is ok, disconnect battery and cmos battery when you solder back chipset, restore security to factory defaults in "Security" tab (or bios to factory defaults in "Main" tab) and should work.
              • c.o.c.o.
                • Jan 2023
                • türkiye
                #47
                Thanks for the reply. I'm new to these stuff, sorry. It seems that I had issues with the CH341A V 1.29 software. The attached files are gathered by asprogrammer. The software asked to choose from multiple chip types. I'm not sure which is which.
                • volinakis
                  • Jan 2021
                  • 2665
                  • N/A
                  #48
                  Leave GD25q128 intact and modify the content of W25Q128 with this one. at 1st boot press F10 and reset security settings to defaults (at bottom of "Security" tab)
                  • c.o.c.o.
                    • Jan 2023
                    • türkiye
                    #49
                    I had some errors during programming. finally I was able to write the file but it didn't work; still asking power-on password - either bios administrator or post power-on password.
                    Anyway, I decided to use "RCUnlocker_v_1_0" and removed password from GD25q128 and it worked like a charm.
                    Thank you.
                    • pixi75
                      • 79
                      • Serbia
                      #50
                      I have problem with unlocking bios password. RC Unlocker doesnt work for me.
                      Here is booth chips.
                      HP Probook440 G7 Serial: 5CD03749CY
                      SKU:8VU03EA#ABH​
                      • rex98
                        • Feb 2023
                        • 1263
                        • Mandaue CEBU, Philippines
                        #51
                        SKU:8VU03EA#ABH​
                        only flash this
                        • pixi75
                          • 79
                          • Serbia
                          #52
                          Originally posted by rex98
                          only flash this
                          Works,Thank you
                          How do you edit it
                          • its service
                            • Feb 2021
                            • 129
                            • india
                            #53
                            hp probook 440-g7
                            SN : #5CD104N2LF
                            Prod id : 2M7G7PC#ACJ
                            motherboard no : DA0X8MMB6D0 REV D
                            problem :End point controller error showing
                            • animorca11
                              • Apr 2023
                              • 8
                              hello Guys urgent ask if anyone can help unlock this bios bin, I would be so thankful sorry for the trouble
                              My device My device
                              HP ProBook 450 G7 Notebook PC
                              product
                              8VU72EA
                              series
                              5CD107QZSN​
                              • rex98
                                • Feb 2023
                                • 1263
                                #55
                                My device My device
                                product
                                8VU72EA
                                series
                                5CD107QZSN​
                                here
                                • animorca11
                                  • Apr 2023
                                  • 8
                                  here
                                  Thank you so so much
                                  • marc_ytos
                                    • Apr 2020
                                    • 141
                                    • cdmx
                                    #57
                                    Greetings, can you help me with my bios to unlock it, it has a passwor and an endepoint security error, my computer is HP 440 g7 motherboard DA0X8MMB6D0 serial number 5CD113HJBG
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11395
                                      • Viet Nam
                                      #58
                                      Passwor and endepoint security error removed.
                                      • ashr88
                                        • Mar 2023
                                        • 55
                                        #59
                                        Hello, please could somebody help me remove the bios password from this:
                                        HP Probook 440 G7
                                        HP Part Number: L78085-601
                                        Motherboard Model: X8M-6L DA0X8MMB6D0 REV: D
                                        THANK YOU!
                                      • ashr88
                                        • Mar 2023
                                        • 55
                                        #60
                                        HP Probook 440 G7
                                        THANK YOU!
                                        I don't have the laptop serial number as I only have the motherboard which doesn't have it on either side? I purchased it as a replacement used motherboard.
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
                                        • Soumana Sanou
                                          “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                          by Soumana Sanou
                                          Hello,😇😇😇
                                          I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                          🔧 Model: HP ProBook 11 G2
                                          📦 Serial Number: 8CG72478MY
                                          🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                          🔒 BIOS Status: Locked with password
                                          The laptop is no longer under warranty and HP refused to help me.
                                          I’m looking for a custom SMC.bin file.
                                          I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                          Thanks a lot for your help!🙏🙏🙏...
                                          06-17-2025, 04:04 PM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
