Panasonic CF-51 BIOS Password
  • AAAC
    • Jan 2020
    • 457
    • Mexico
    Re: Panasonic CF-51 BIOS Password
    @gius0161
    Seems to me that this Panasonic Toughbook CF-51 (mk2) is an old model, that still haves a parallel port, so one solution is to build the "Password Skipping Plug". Unfortunately this only seem to work just for the USER password.
    In old models the password used to be stored in EEPROM, did check your files. My suggestion is to look for an eeprom near the EC/KBC (check on both sides).
    Did some Google searches and found a link to AllService forum and to laptops.shoutwiki.com, you may be able to follow procedure posted at AllService to reset the password by updating the EC/KBC and BIOS.
    When "Enter password" is displayed, use "Password Skipping Plug" in order to skip the user password.
    1) Connect the parallel plug to the parallel port.
    2) Connect the PS/2 mouse plug to the mouse port.
    3) Power on the computer.
    The wiring of the parallel plug is described below.
    Connect pins 2-5-6-8-11-13-15-18-19-20-21-22-23 to Shield GND (PS/2 mouse plug pin 3.)
    Connect pins 3-4-7-9-10-12 to VC5 (PS/2 mouse plug pin 4) with 4.7KW each.
    • gzljw
      • Dec 2020
      • 18
      • china
      I also have a cf-51 with a BIOS password. Please give me a BIOS without a password
      • gzljw
        • Dec 2020
        • 18
        • china
        up
        • ARealUserOMG
          • Apr 2025
          Hi, I've got an Panasonic CF-52 Mk1 Laptop and tried to get it to work again.
          But I just can't get around this Bios Password. (Supervisor and User Password)
          Sadly I don't have any numbers except the ones on the motherboard.
          I dumped the bios chip, it's an SST25VF080B chip. With a sticker saying DL3UA1656EAA and on the PCB it says DFUP1656ZB(A)
          I dumped the bios with a CH341A dumper. (I'm open to hear If I did anything wrong while dumping)
          On trying to boot before the password prompt comes it shows some infos about the bios for a short second. The BIOS Version is 1.54-L25 and its a Phoenix TrustedCore(tm) NB
          Next to the RAM i found these numbers on 2 stickers:
          CF52MK1L181 | 07211
          CF52MK1L10G08287
          Is anyone able to remove the password or decrypt it?
          I will include the bios dump.
          Wish you all the best
          And a wonderful day :>
            SMDFlea commented
            Editing a comment
            Thread merged.
        • ARealUserOMG
          • Apr 2025
          For anyone who might have the same problem.
          I managed to remove the password.
          It is the model CF52CCABVAG, (mk1L)
          What I did was:
          1. Disassemble the Notebook
          2. Disconnect the CMOS Battery (this wasn't enough to delete my password yet though)
          3. Now the funny part, when you short the CMOS Battery Pins at the right time while trying to boot the notebook, you can somehow make it falsely read the checksum from the chip.
          The Bios will than revert to standard values and saves them.
          You now have a unlocked Bios
          I hope someday this helps someone :>
          Have a wonderful day ya all :>
          • outsider
            Panasonic FZ-G1 MK5 - BIOS password returning
            by outsider
            Hello
            I removed the BIOS password thanks to the help of one of the friends of this forum.
            https://www.badcaps.net/forum/troubl...61#post3637661
            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
            06-17-2025, 12:51 AM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • traxformania
            TONGFANG "GM7TG7P" Bios Password Problem?
            by traxformania
            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
            I'm trying to reset my bios without success.
            I tried :
            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
            11-15-2023, 07:32 AM
          • Nopslide
            HP Omen 15-dh0052nf power-on & bios password
            by Nopslide
            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
            04-01-2024, 04:27 PM
          • AquaMan Ua
            Problem with PANASONIC CF53 laptop after changing BIOS settings
            by AquaMan Ua
            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
            05-17-2025, 09:40 AM
